メインコンテンツにスキップ
HTC One X LCD Display & Touch Screen Glass Digitizer Replacement
必要な工具と部品
ビデオの概要
  1. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement, LCD Display & Touchscreen: 手順 1、 3の画像 1 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement, LCD Display & Touchscreen: 手順 1、 3の画像 2 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement, LCD Display & Touchscreen: 手順 1、 3の画像 3
    • Switch-off the phone (if you can).
    • Remove the SIM tray.
    • The back cover is sticked to the phone with adhesive tape. Is good to use some hot air to do removing of the back cover easier.
  2. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 2、 3の画像 1 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 2、 3の画像 2 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 2、 3の画像 3
    • Start opening from the bottom side.
    • For separating the back cover, use only plastic tools.
  3. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 3、 3の画像 1 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 3、 3の画像 2 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 3、 3の画像 3
    • The mother board is held by 6x Philips screws.
  4. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 4、 3の画像 1 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 4、 3の画像 2 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 4、 3の画像 3
    • Disconnect one by one:
    • the Touchscreen flex cable
    • the Volume buttons & Mic flex cable
    • the Dock connector flex cable
    • Use a plastic tool to unstick the battery.
    • Be careful, there are flex cables under the battery. At the last picture in this step you can see the cables and the place were is adhesive tape.
    • Now you can separate the Dock flex cable.
  5. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 5、 3の画像 1 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 5、 3の画像 2 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 5、 3の画像 3
    • Lift the motherboard slightly to disconnect two flex cables:
    • the LCD Display flex cable
    • the Navigation buttons flex cable
    • Disconnect the Power On button flex cable at the upper side of the phone
    • Now the mainboard and the battery are free.
    • Disconnect the battery from the mainboard.
  6. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 6、 3の画像 1 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 6、 3の画像 2 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 6、 3の画像 3
    • At the beginning you can use a cutter to make a room for the plastic tool.
    • During the procedure of the separating the LCD Display & Touchscreen from the frame, you can use again hot air. This will make separating more easy.
  7. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 7、 3の画像 1 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 7、 3の画像 2 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 7、 3の画像 3
    • The original adhesive tape is left on the frame, but I prefer to put new. I put it onto the original.
    • Gently assemble the screen to the frame.
  8. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: 手順 8、 1の画像 1
終わりに
14 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
ZFix
メンバー登録日: 12/09/13
191,278 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,528のガイドは作成済み
コメント 1 件
i need touch panel do you have available
osama siddique - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 38,260
