メインコンテンツにスキップ
HTC One X Battery Replacement
必要な工具と部品
ビデオの概要
  1. HTC One X Battery Replacement, Battery: 手順 1、 3の画像 1 HTC One X Battery Replacement, Battery: 手順 1、 3の画像 2 HTC One X Battery Replacement, Battery: 手順 1、 3の画像 3
    • Switch the phone off.
    • Remove the SIM tray.
    • The back cover is stuck to the phone with adhesive tape.
    • It's helpful to use heat to loosen the adhesive, making removal much easier.
  2. HTC One X Battery Replacement: 手順 2、 3の画像 1 HTC One X Battery Replacement: 手順 2、 3の画像 2 HTC One X Battery Replacement: 手順 2、 3の画像 3
    • Start opening from the bottom side.
    • For separating the back cover, use only plastic tools.
  3. HTC One X Battery Replacement: 手順 3、 2の画像 1 HTC One X Battery Replacement: 手順 3、 2の画像 2
    • Remove the display assembly from the body of the phone.
  4. HTC One X Battery Replacement: 手順 4、 2の画像 1 HTC One X Battery Replacement: 手順 4、 2の画像 2
    • Remove the seven Philips #0 screws at the top of the panel:
    • Two 2.05 mm screws
    • Three 2.44 mm screws
    • Two 3.35 mm screws
    • Once the screws are removed, gently remove the plastic cover using a plastic opening tool to detach the edges from the front panel.
  5. HTC One X Battery Replacement: 手順 5、 3の画像 1 HTC One X Battery Replacement: 手順 5、 3の画像 2 HTC One X Battery Replacement: 手順 5、 3の画像 3
    • Disconnect one by one:
    • the Touchscreen flex cable
    • the Volume buttons & Mic flex cable
    • the Dock connector flex cable
    • Carefully insert a plastic tool under the battery to pry it up from the adhesive. Avoid bending the battery.
    • Be careful, there are flex cables under the battery. At the last picture in this step you can see the cables and the place were is adhesive tape.
    • Now you can separate the Dock flex cable.
  6. HTC One X Battery Replacement: 手順 6、 2の画像 1 HTC One X Battery Replacement: 手順 6、 2の画像 2
    • A piece of copper tape covers the battery and an EMI shield on the motherboard.
    • Carefully pry the EMI shield up at the top of the phone and toward the battery.
    • Carefully peel the copper tape off of the battery and save it to transfer to the new battery.
  7. HTC One X Battery Replacement: 手順 7、 3の画像 1 HTC One X Battery Replacement: 手順 7、 3の画像 2 HTC One X Battery Replacement: 手順 7、 3の画像 3
    • Lift the motherboard slightly to disconnect two flex cables:
    • the LCD Display flex cable
    • the Navigation buttons flex cable
    • Disconnect the Power On button flex cable at the upper side of the phone
    • Now the mainboard and the battery are free.
    • Disconnect the battery and you are ready to install the new one.
  8. HTC One X Battery Replacement: 手順 8、 2の画像 1 HTC One X Battery Replacement: 手順 8、 2の画像 2
終わりに
13 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
ZFix
メンバー登録日: 12/09/13
191,308 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,535のガイドは作成済み
2 件のコメント
Perfecto! Me vino genial el tutorial y es perfecto, mejor que otros.
hepugh - 返信
Went very well. I had a dead HTC One X that I replaced 4 years ago. I came across it a few weeks ago and thought to give a new battery a try, to see if I can get the photos off it. It did not charge (no lights) and did not turn on anymore. I ordered a battery from AliExpress and it came in today. Followed this guide, and yes, it turned on again! And charging is also working properly now. So I am happy, now I can get my photos and use the phone as a Android 4.2 testing target for the apps I develop. Wonderful.
Peterdk - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 33
今までの合計 46,519
