メインコンテンツにスキップ
HTC One X Antenna Replacement
必要な工具と部品
  1. HTC One X Antenna Replacement, Squeeze Test: 手順 1、 1の画像 1
    • Before replacement of the antenna, carry out the squeeze test.
    • Gently squeeze your device between the camera lens and the volume button. This should temporarily reconnect the antenna if it's loose.
    • If the squeeze test doesn't reconnect your wi-fi/bluetooth then move to step 2
  2. HTC One X Antenna Replacement, Remove SIM card slot: 手順 2、 1の画像 1
    • Insert a safety pin, or other small object into the narrow aperture next to the Sim Card Slot to remove the SIM card.
    • The Sim Card Slot is located at the top of the rear panel.
  3. HTC One X Antenna Replacement, Remove front panel: 手順 3、 2の画像 1 HTC One X Antenna Replacement, Remove front panel: 手順 3、 2の画像 2
    • Use a plastic opening tool, and carefully insert it between the display and rear panel. Separate the two parts.
    • The display assembly is a tight fit therefore the removal must be carried out carefully with firm, constant force being applied around the bottom corners and sides of the panel. Note that the top of the phone is underneath the panel, and will not come out.
    • If your display is cracked, take extra caution when separating the display from the rear panel to prevent further breakage or bodily harm.
    • Set aside the rear panel for now
  4. HTC One X Antenna Replacement, Replace antenna: 手順 4、 1の画像 1
    • Once the rear panel is separated from the front panel, remove the antenna using tweezers.
    • The antenna is located on the right hand side of the front panel as indicated in the image.
    • Replace and reconnect the new antenna in the same position as the faulty one you just removed. Remember to place it underneath the metal supports on the board.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Blain Abebe
メンバー登録日: 09/22/14
766 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 4-3, Brown Fall 2014 USF Tampa, Team 4-3, Brown Fall 2014人のメンバー
USFT-BROWN-F14S4G3
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 9,323
