Use the plastic opening tool to loosen the adhesive from the crease surrounding the screen.
The volume button is a good place to begin, it should come right out as you pry.
Wedge the plastic opening tool into the crack around the screen, on only the top, left and right sides.
Applying heat with the iOpener or a heat gun can speed this process.
Once the screen has been loosened on the top, left and right edges, lift the screen. It will remain attached at the bottom on a hinge.
The screen will remain attached to this hinge until the final step.
この手順で使用する道具:
購入する
Reach beneath the motherboard with the tweezers , grip it and lift.
Lift with care, the motherboard is not completely disconnected yet.
Remove the tape connecting the motherboard to the phone and gently lift it out.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
