メインコンテンツにスキップ
HTC One Mini 2 Motherboard Replacement
必要な工具と部品
  1. HTC One Mini 2 Motherboard Replacement, Sim and MicroSD Card: 手順 1、 3の画像 1 HTC One Mini 2 Motherboard Replacement, Sim and MicroSD Card: 手順 1、 3の画像 2 HTC One Mini 2 Motherboard Replacement, Sim and MicroSD Card: 手順 1、 3の画像 3
    • Insert the end of a paper clip into the holes on each side of the phone to eject the SIM card and Micro SD card.
    • Set the cardholders aside.
  2. HTC One Mini 2 Motherboard Replacement: 手順 2、 1の画像 1
    • Heat up the top grey speaker plate with the iFixit iOpener for two minutes.
  3. HTC One Mini 2 Motherboard Replacement, Front Plate: 手順 3、 3の画像 1 HTC One Mini 2 Motherboard Replacement, Front Plate: 手順 3、 3の画像 2 HTC One Mini 2 Motherboard Replacement, Front Plate: 手順 3、 3の画像 3
    • Use a metal spudger to pry up the left edge of the upper grey front plate.
    • Place the spudger between the inside white plastic edge and the grey plate. Do not pry between the two white plastic frames.
    • Don’t pry against the glass. Pry against only the left side as there is a delicate antenna under the plate.
    • Use the narrow plastic pry tool to carefully separate the black ribbon antenna from the grey plate.
  4. HTC One Mini 2 Motherboard Replacement: 手順 4、 2の画像 1 HTC One Mini 2 Motherboard Replacement: 手順 4、 2の画像 2
    • Remove the 2mm screw with a T5 torx screwdriver head from the iFixit tool kit.
  5. HTC One Mini 2 Motherboard Replacement: 手順 5、 2の画像 1 HTC One Mini 2 Motherboard Replacement: 手順 5、 2の画像 2
    • Use the plastic pry tool to pry around the edge of the phone.
    • Pry carefully around the card slots.
    • Slowly pull up from the right side of the screen like opening a book.
    • The plastic piece for the power button may fall out. Set it aside for reassembly.
    • Use the plastic spudger to peel the foam adhesive around the camera away from the back plate.
  6. HTC One Mini 2 Motherboard Replacement, Motherboard: 手順 6、 2の画像 1 HTC One Mini 2 Motherboard Replacement, Motherboard: 手順 6、 2の画像 2
    • Peel off the long yellow pieces of tape on the right and left side of the copper plate.
  7. HTC One Mini 2 Motherboard Replacement: 手順 7、 1の画像 1
    • Starting from the copper plate, peel up all three woven, silver colored tapes using the spudger or narrow pry tool.
  8. HTC One Mini 2 Motherboard Replacement: 手順 8、 3の画像 1 HTC One Mini 2 Motherboard Replacement: 手順 8、 3の画像 2 HTC One Mini 2 Motherboard Replacement: 手順 8、 3の画像 3
    • Using the flat end of the spudger, pop up the white tabs on all ribbon cable connectors located to the left and right of the copper plate.
    • On the left side, pop the white tab up to the left. On the right, pop up to the right.
    • Carefully pull out the ribbon cables.
  9. HTC One Mini 2 Motherboard Replacement: 手順 9、 3の画像 1 HTC One Mini 2 Motherboard Replacement: 手順 9、 3の画像 2 HTC One Mini 2 Motherboard Replacement: 手順 9、 3の画像 3
    • Using a Phillips #00 screwdriver, unscrew the two 1 mm screws from the bottom right corner of the motherboard that hold the power connector down.
    • Pop up the battery connector using the flat end of the spudger.
  10. HTC One Mini 2 Motherboard Replacement: 手順 10、 3の画像 1 HTC One Mini 2 Motherboard Replacement: 手順 10、 3の画像 2 HTC One Mini 2 Motherboard Replacement: 手順 10、 3の画像 3
    • Use the pointed end of the spudger to pop off the four antenna connectors. Three are located on the top left corner of the motherboard and one on the bottom right.
  11. HTC One Mini 2 Motherboard Replacement: 手順 11、 2の画像 1 HTC One Mini 2 Motherboard Replacement: 手順 11、 2の画像 2
    • Using the pointed end of the spudger, pull the wires for the rumble motor to the left to pull the connector out of the board.
    • The connector is very small and easy to break so take caution when pulling it out. Wiggling the wires as you pull to the left helps.
  12. HTC One Mini 2 Motherboard Replacement: 手順 12、 3の画像 1 HTC One Mini 2 Motherboard Replacement: 手順 12、 3の画像 2 HTC One Mini 2 Motherboard Replacement: 手順 12、 3の画像 3
    • Using a T5 torx screwdriver, remove four 2mm screws from the four corners of the motherboard.
    • Once the screws are removed, carefully pull the copper plated motherboard out.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Jeron Hogan
メンバー登録日: 10/14/14
818 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 4-48, Amido Fall 2014 Cal Poly, Team 4-48, Amido Fall 2014人のメンバー
CPSU-AMIDO-F14S4G48
5 メンバー
17のガイドは作成済み
コメント 1 件
Does anyone know which ribbon cable is for the NAND drive? After replacing the LCD, I no longer can boot up my phone. It only goes into bootloader screen
Rich
Rich Sigle - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 5,798
