メインコンテンツにスキップ
HTC One Max Rear Facing Camera Replacement
必要な工具と部品
  1. HTC One Max Rear Facing Camera Replacement, Back Case: 手順 1、 1の画像 1
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
  2. HTC One Max Rear Facing Camera Replacement: 手順 2、 2の画像 1 HTC One Max Rear Facing Camera Replacement: 手順 2、 2の画像 2
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
  3. HTC One Max Rear Facing Camera Replacement: 手順 3、 1の画像 1
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
  4. HTC One Max Rear Facing Camera Replacement: 手順 4、 2の画像 1 HTC One Max Rear Facing Camera Replacement: 手順 4、 2の画像 2
    • Use the small plastic opening tool to pry between the screen and the rear case.
  5. HTC One Max Rear Facing Camera Replacement, Fingerprint Sensor: 手順 5、 2の画像 1 HTC One Max Rear Facing Camera Replacement, Fingerprint Sensor: 手順 5、 2の画像 2
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
  6. HTC One Max Rear Facing Camera Replacement, Motherboard: 手順 6、 2の画像 1 HTC One Max Rear Facing Camera Replacement, Motherboard: 手順 6、 2の画像 2
    • Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
    • Use a plastic tool to remove the ribbon cable.
  7. HTC One Max Rear Facing Camera Replacement: 手順 7、 2の画像 1 HTC One Max Rear Facing Camera Replacement: 手順 7、 2の画像 2
    • Use the plastic opening tool to disconnect the two antenna wires at the top of the phone.
    • Use the plastic opening tool to disconnect a third antenna wire at the bottom of the phone.
  8. HTC One Max Rear Facing Camera Replacement: 手順 8、 1の画像 1
    • Remove the seven 3 mm Phillips #000 screws from the motherboard.
  9. HTC One Max Rear Facing Camera Replacement: 手順 9、 3の画像 1 HTC One Max Rear Facing Camera Replacement: 手順 9、 3の画像 2 HTC One Max Rear Facing Camera Replacement: 手順 9、 3の画像 3
    • Use a plastic tool to pry up and disconnect the large ribbon cables on each side of the motherboard.
    • Use caution prying the ribbon cable on the right side because other ribbon cables run under it.
  10. HTC One Max Rear Facing Camera Replacement: 手順 10、 3の画像 1 HTC One Max Rear Facing Camera Replacement: 手順 10、 3の画像 2 HTC One Max Rear Facing Camera Replacement: 手順 10、 3の画像 3
    • Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
    • Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
  11. HTC One Max Rear Facing Camera Replacement: 手順 11、 2の画像 1 HTC One Max Rear Facing Camera Replacement: 手順 11、 2の画像 2
    • Use a plastic tool to lift and remove the motherboard.
    • Use a heat gun to loosen adhesive at bottom if needed.
  12. HTC One Max Rear Facing Camera Replacement, IR Blaster: 手順 12、 1の画像 1
    • Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
  13. HTC One Max Rear Facing Camera Replacement: 手順 13、 1の画像 1
    • Pick up and set aside vibrator, do not disconnect.
  14. HTC One Max Rear Facing Camera Replacement: 手順 14、 1の画像 1
    • Pull out ribbon cable.
    • Peel back infrared sensor.
  15. HTC One Max Rear Facing Camera Replacement, Rear Facing Camera: 手順 15、 2の画像 1 HTC One Max Rear Facing Camera Replacement, Rear Facing Camera: 手順 15、 2の画像 2
    • Lift the secondary motherboard with the camera attached.
  16. HTC One Max Rear Facing Camera Replacement: 手順 16、 3の画像 1 HTC One Max Rear Facing Camera Replacement: 手順 16、 3の画像 2 HTC One Max Rear Facing Camera Replacement: 手順 16、 3の画像 3
    • Use a plastic opening tool to disconnect the camera ribbon cable.
    • Remove rear camera.
終わりに
8 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Andrew Keller
メンバー登録日: 09/23/14
1,131 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 11-3, Blackwell Fall 2014 USF Tampa, Team 11-3, Blackwell Fall 2014人のメンバー
USFT-BLACKWELL-F14S11G3
4 メンバー
7のガイドは作成済み
コメント 1 件
so..which one do i have to buy?
the Phillips #00 or the #000? the steps say one thing, the required tools section says another.
thanks in advance
alberto rivera - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 8,039
