はじめに
You will learn how to replace a faulty microphone on an HTC One Max in this guide.
必要な工具と部品
Lift back cover while pressing highlighted release switch towards the center of the phone.
Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
Use a plastic tool to remove the ribbon cable.
Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
Remove the two 2.8 mm Phillips #000 screws from the metal plate near the bottom of the phone.
3 の人々がこのガイドを完成させました。
