このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
この手順は未翻訳です。 翻訳を手伝う。
Use the plastic opening tool to scrape and loosen the adhesive from the crease surrounding the screen.
A good place to start is the volume button and it should come right out as you pry.
Wedge the plastic opening tool into the crack around the screen on the top, left and right sides.
This step can be sped up by using a heat gun or iOpener to heat up the glue.
Once the screen has been loosened on the top, left and right edges, lift the screen.
The screen will stay on a hinge until the final step.
Gently remove the volume button. Using the plastic opening tool, loosen the back panel of the phone. Begin in the space where the battery was and work around the phone, following the crease of the back panel.
Pry the back open once loose and lift. The back panel will come off with time.
Remove all the #000 screws with a #000 Phillips screw driver
Some screws are hidden by tape so remove the tape and check for screws.
Use the tweezers to get underneath the mother board to lift.
Lift slowly because it is not fully disconnected yet.
Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it).
Lift the camera out of the motherboard.
Lift the motherboard completely out of the phone. (may stay attached at the bottom by tape)
Use the blue opening tool to pry up the battery from the frame.
The battery is glued to the frame so you will have to put force.
Do not break the battery upon removal.
Remove the motherboard entirely if not done on step 9.
Remove the screws in the speaker at the bottom of the frame.
Lift the speaker out of the frame.
Lift the screen out of its hinge.
Replace the screen.
キャンセル: このガイドを終了できませんでした。
16 の人々がこのガイドを完成させました。
3人の作成者と共同で作成されました。
メンバー登録日: 09/23/14
1,838 ポイント
2のガイドは作成済み
バッジ: 14
+11 個以上のバッジ
USFT-BLACKWELL-F14S12G1
4 メンバー
7のガイドは作成済み
Thanks for the tutorial. Not the most repair friendly device,! It took me 2,5 hours, so it's surely possible to do it faster than 10 hours ;)
Albert Zweistein - 2016年11月18日 返信
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
過去 24時間: 2
過去 7 日: 7
過去 30 日: 12
今までの合計 18,245
