メインコンテンツにスキップ
HTC One Front Panel Replacement
必要な工具と部品
  1. HTC One Front Panel Replacement, Front Panel: 手順 1、 2の画像 1 HTC One Front Panel Replacement, Front Panel: 手順 1、 2の画像 2
    • Use the plastic opening tool to scrape and loosen the adhesive from the crease surrounding the screen.
    • A good place to start is the volume button and it should come right out as you pry.
  2. HTC One Front Panel Replacement: 手順 2、 1の画像 1
    • Wedge the plastic opening tool into the crack around the screen on the top, left and right sides.
    • This step can be sped up by using a heat gun or iOpener to heat up the glue.
  3. HTC One Front Panel Replacement: 手順 3、 2の画像 1 HTC One Front Panel Replacement: 手順 3、 2の画像 2
    • Once the screen has been loosened on the top, left and right edges, lift the screen.
    • The screen will stay on a hinge until the final step.
  4. HTC One Front Panel Replacement: 手順 4、 1の画像 1
    • Gently remove the volume button. Using the plastic opening tool, loosen the back panel of the phone. Begin in the space where the battery was and work around the phone, following the crease of the back panel.
  5. HTC One Front Panel Replacement: 手順 5、 2の画像 1 HTC One Front Panel Replacement: 手順 5、 2の画像 2
    • Pry the back open once loose and lift. The back panel will come off with time.
  6. HTC One Front Panel Replacement: 手順 6、 3の画像 1 HTC One Front Panel Replacement: 手順 6、 3の画像 2 HTC One Front Panel Replacement: 手順 6、 3の画像 3
    • Remove all the #000 screws with a #000 Phillips screw driver
    • Some screws are hidden by tape so remove the tape and check for screws.
  7. HTC One Front Panel Replacement: 手順 7、 1の画像 1
    • Use the tweezers to get underneath the mother board to lift.
    • Lift slowly because it is not fully disconnected yet.
  8. HTC One Front Panel Replacement: 手順 8、 2の画像 1 HTC One Front Panel Replacement: 手順 8、 2の画像 2
    • Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it).
    • Lift the camera out of the motherboard.
  9. HTC One Front Panel Replacement: 手順 9、 2の画像 1 HTC One Front Panel Replacement: 手順 9、 2の画像 2
    • Lift the motherboard completely out of the phone. (may stay attached at the bottom by tape)
  10. HTC One Front Panel Replacement: 手順 10、 2の画像 1 HTC One Front Panel Replacement: 手順 10、 2の画像 2
    • Use the blue opening tool to pry up the battery from the frame.
    • The battery is glued to the frame so you will have to put force.
    • Do not break the battery upon removal.
  11. HTC One Front Panel Replacement: 手順 11、 3の画像 1 HTC One Front Panel Replacement: 手順 11、 3の画像 2 HTC One Front Panel Replacement: 手順 11、 3の画像 3
    • Remove the motherboard entirely if not done on step 9.
  12. HTC One Front Panel Replacement: 手順 12、 2の画像 1 HTC One Front Panel Replacement: 手順 12、 2の画像 2
    • Remove the screws in the speaker at the bottom of the frame.
    • Lift the speaker out of the frame.
  13. HTC One Front Panel Replacement: 手順 13、 1の画像 1
    • Lift the screen out of its hinge.
    • Replace the screen.
終わりに
16 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jeremy
メンバー登録日: 09/23/14
1,838 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 12-1, Blackwell Fall 2014 USF Tampa, Team 12-1, Blackwell Fall 2014人のメンバー
USFT-BLACKWELL-F14S12G1
4 メンバー
7のガイドは作成済み
コメント 1 件
Thanks for the tutorial. Not the most repair friendly device,! It took me 2,5 hours, so it's surely possible to do it faster than 10 hours ;)
Albert Zweistein - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 18,238
