メインコンテンツにスキップ
HTC Maple 100 Internal Ear Speaker Replacement
必要な工具と部品
  1. HTC Maple 100 Internal Ear Speaker Replacement, Battery: 手順 1、 1の画像 1
    • First remove the back cover of your phone to expose the battery.
  2. HTC Maple 100 Internal Ear Speaker Replacement: 手順 2、 1の画像 1
    • Turn the phone over.
    • Push forward on the battery with your thumb.
  3. HTC Maple 100 Internal Ear Speaker Replacement: 手順 3、 2の画像 1 HTC Maple 100 Internal Ear Speaker Replacement: 手順 3、 2の画像 2
    • Take the battery out by lifting it upwards.
    • When reassembling, make sure that the battery contacts match up.
  4. HTC Maple 100 Internal Ear Speaker Replacement, Back Panel: 手順 4、 2の画像 1 HTC Maple 100 Internal Ear Speaker Replacement, Back Panel: 手順 4、 2の画像 2
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
  5. HTC Maple 100 Internal Ear Speaker Replacement: 手順 5、 1の画像 1
    • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
  6. HTC Maple 100 Internal Ear Speaker Replacement: 手順 6、 3の画像 1 HTC Maple 100 Internal Ear Speaker Replacement: 手順 6、 3の画像 2 HTC Maple 100 Internal Ear Speaker Replacement: 手順 6、 3の画像 3
    • Insert the plastic opening tool along the seams at different points to it pry the clips off.
    • This may require a bit of force. The USB port cover may fall off in this step.
  7. HTC Maple 100 Internal Ear Speaker Replacement, Motherboard: 手順 7、 2の画像 1 HTC Maple 100 Internal Ear Speaker Replacement, Motherboard: 手順 7、 2の画像 2
    • Remove the one 3.3mm Phillips #00 screw.
  8. HTC Maple 100 Internal Ear Speaker Replacement: 手順 8、 2の画像 1 HTC Maple 100 Internal Ear Speaker Replacement: 手順 8、 2の画像 2
    • Use your finger or the plastic opening tool to unclip the board.
    • Be aware of the ribbon cable connected to the motherboard inside the phone.
  9. HTC Maple 100 Internal Ear Speaker Replacement: 手順 9、 2の画像 1 HTC Maple 100 Internal Ear Speaker Replacement: 手順 9、 2の画像 2
    • Peel off the yellow piece of tape from the phone.
  10. HTC Maple 100 Internal Ear Speaker Replacement: 手順 10、 3の画像 1 HTC Maple 100 Internal Ear Speaker Replacement: 手順 10、 3の画像 2 HTC Maple 100 Internal Ear Speaker Replacement: 手順 10、 3の画像 3
    • Flip up the retaining flap with your fingernail or a plastic opening tool.
    • Pull on the ribbon cable gently with your fingers.
  11. HTC Maple 100 Internal Ear Speaker Replacement: 手順 11、 2の画像 1 HTC Maple 100 Internal Ear Speaker Replacement: 手順 11、 2の画像 2
    • Split apart the motherboard and front panel.
    • Remove the other yellow piece of tape off of the end of the ribbon cable.
  12. HTC Maple 100 Internal Ear Speaker Replacement: 手順 12、 2の画像 1 HTC Maple 100 Internal Ear Speaker Replacement: 手順 12、 2の画像 2
    • Gently pull on the ribbon cable to separate the motherboard.
  13. HTC Maple 100 Internal Ear Speaker Replacement, Internal Ear Speaker: 手順 13、 1の画像 1
    • Locate the internal speaker at the top center of the phone.
  14. HTC Maple 100 Internal Ear Speaker Replacement: 手順 14、 2の画像 1 HTC Maple 100 Internal Ear Speaker Replacement: 手順 14、 2の画像 2
    • Using the plastic opening tool, carefully pry out the internal speaker.
終わりに
作成者
4人の作成者と共同で作成されました。
Alyssa Thompson
メンバー登録日: 10/04/11
11 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 20-29, Maness Fall 2011 Cal Poly, Team 20-29, Maness Fall 2011人のメンバー
CPSU-MANESS-F11S20G29
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 767
