メインコンテンツにスキップ
HTC Magic Speaker Replacement
必要な工具と部品
  1. HTC Magic Speaker Replacement, Speaker: 手順 1、 3の画像 1 HTC Magic Speaker Replacement, Speaker: 手順 1、 3の画像 2 HTC Magic Speaker Replacement, Speaker: 手順 1、 3の画像 3
    • Open the phone by removing it's backcover (battery door) and the battery.
    • REMEMBER to remove the simcard and microSD card. If you do not they'll be damaged when you remove them at a later stage.
  2. HTC Magic Speaker Replacement: 手順 2、 1の画像 1
    • Unscrew the six screws with a Torx T5 screwdriver.
  3. HTC Magic Speaker Replacement: 手順 3、 2の画像 1 HTC Magic Speaker Replacement: 手順 3、 2の画像 2
    • Remove the antenna (use the little gap at the top ).
    • Use the iPod opening tools (or your fingernails) to remove the hosuing by running along the seam bit by bit. It's easiest to start somewhere in the middle, then work your way across the top.
    • The housing is held by plastic clips, so be careful since you don't want to break these.
    • Carefully lift the front housing from the back.
  4. HTC Magic Speaker Replacement: 手順 5、 2の画像 1 HTC Magic Speaker Replacement: 手順 5、 2の画像 2
    • The rear housing should look like the picture on the left. The speaker part is at the top.
    • Use a small bit (like a paperclip) to lift the speaker out of it's socket. It's glued in it's place, so you may need to use a bit of force.
    • Be sure not to touch any part of the speaker except the black plastic parts.
終わりに
作成者
2人の作成者と共同で作成されました。
LucasJV
メンバー登録日: 05/18/10
735 ポイント
3のガイドは作成済み
チーム
Verheij.co Verheij.co人のメンバー
Business
1 メンバー
5のガイドは作成済み
コメント 1 件
Where can I buy a speaker's set for the HTC Magic, please?
Miguel Ponce - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 10,710
