メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
A part that might fail after you drop your HTC Magic is the speaker. Here's how to replace it. You will need Torx T6 & T5 drivers , a screwdriver, & a iPod opening tool(s).
パーツ
パーツは指定されていません。
  1. Open the phone by removing it's backcover (battery door) and the battery. REMEMBER to remove the simcard and microSD card. If you do not they'll be damaged when you remove them at a later stage. REMEMBER to remove the simcard and microSD card. If you do not they'll be damaged when you remove them at a later stage.
    • Open the phone by removing it's backcover (battery door) and the battery.
    • REMEMBER to remove the simcard and microSD card. If you do not they'll be damaged when you remove them at a later stage.
  2. Unscrew the six screws with a Torx T5 screwdriver.
    • Unscrew the six screws with a Torx T5 screwdriver.
  3. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  4. Remove the antenna (use the little gap at the top ). Remove the antenna (use the little gap at the top ).
    • Remove the antenna (use the little gap at the top ).
    • Use the iPod opening tools (or your fingernails) to remove the hosuing by running along the seam bit by bit. It's easiest to start somewhere in the middle, then work your way across the top.
    • The housing is held by plastic clips, so be careful since you don't want to break these.
    • Carefully lift the front housing from the back.
  5. The rear housing should look like the picture on the left. The speaker part is at the top. Use a small bit (like a paperclip) to lift the speaker out of it's socket. It's glued in it's place, so you may need to use a bit of force.
    • The rear housing should look like the picture on the left. The speaker part is at the top.
    • Use a small bit (like a paperclip) to lift the speaker out of it's socket. It's glued in it's place, so you may need to use a bit of force.
    • Be sure not to touch any part of the speaker except the black plastic parts.
終わりに
LucasJV
メンバー登録日: 2010年05月18日
717 ポイント
3のガイドは作成済み
チーム
Verheij.co Verheij.co人のメンバー
Business
1 メンバー
3のガイドは作成済み
コメント1件
Where can I buy a speaker's set for the HTC Magic, please?
Miguel Ponce - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 10,571
