はじめに
Having trouble adjusting the phone's volume? This guide will walk you through the steps of how to access and replace the audio controls.
必要な工具と部品
Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
Firmly grasp the volume button from the mid panel on the clip side
Gently lift the button upwards and remove it
2 の人々がこのガイドを完成させました。
