メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HTC Incredible 2 Volume Button Replacement
必要な工具と部品
  1. HTC Incredible 2 Volume Button Replacement, Disassembling HTC Incredible 2 Back Panel: 手順 1、 2の画像 1 HTC Incredible 2 Volume Button Replacement, Disassembling HTC Incredible 2 Back Panel: 手順 1、 2の画像 2
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
    FixBotに聞いてみる
    コメントを追加
  2. HTC Incredible 2 Volume Button Replacement: 手順 2、 1の画像 1
    • Remove the rear panel from the phone.
    FixBotに聞いてみる
    コメントを追加
  3. HTC Incredible 2 Volume Button Replacement, Battery: 手順 3、 1の画像 1
    • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Use a penny or dime if you can't use your fingernail.
    FixBotに聞いてみる
    コメントを追加
  4. HTC Incredible 2 Volume Button Replacement: 手順 4、 2の画像 1 HTC Incredible 2 Volume Button Replacement: 手順 4、 2の画像 2
    • Gently lever the battery up and away from the lights.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
    FixBotに聞いてみる
    コメントを追加
  5. HTC Incredible 2 Volume Button Replacement, Mid Panel: 手順 5、 1の画像 1
    • Remove the seven 1.42 mm Torx T5 screws
    FixBotに聞いてみる
    コメントを追加
  6. HTC Incredible 2 Volume Button Replacement: 手順 6、 2の画像 1 HTC Incredible 2 Volume Button Replacement: 手順 6、 2の画像 2
    • Use a plastic opening tool to run along the phone's side and lever mid panel upward.
    • Apply minimal pressure as the mid panel is very delicate.
    FixBotに聞いてみる
    コメントを追加
  7. HTC Incredible 2 Volume Button Replacement: 手順 7、 1の画像 1
    • Gently grasp and carefully lift mid panel up and away from the device with your fingers.
    FixBotに聞いてみる
    コメントを追加
  8. HTC Incredible 2 Volume Button Replacement, Volume Button: 手順 8、 3の画像 1 HTC Incredible 2 Volume Button Replacement, Volume Button: 手順 8、 3の画像 2 HTC Incredible 2 Volume Button Replacement, Volume Button: 手順 8、 3の画像 3
    • Firmly grasp the volume button from the mid panel on the clip side
    • Gently lift the button upwards and remove it
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Robert Trujillo
メンバー登録日: 04/25/14
246 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 11-53, Amido Spring 2014 Cal Poly, Team 11-53, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S11G53
5 メンバー
28のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 17
今までの合計 581
