メインコンテンツにスキップ
HTC Incredible 2 SIM Card Replacement
  1. HTC Incredible 2 SIM Card Replacement, Disassembling HTC Incredible 2 Back Panel: 手順 1、 2の画像 1 HTC Incredible 2 SIM Card Replacement, Disassembling HTC Incredible 2 Back Panel: 手順 1、 2の画像 2
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
  2. HTC Incredible 2 SIM Card Replacement: 手順 2、 1の画像 1
    • Remove the rear panel from the phone.
  3. HTC Incredible 2 SIM Card Replacement, Battery: 手順 3、 1の画像 1
    • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Use a penny or dime if you can't use your fingernail.
  4. HTC Incredible 2 SIM Card Replacement: 手順 4、 2の画像 1 HTC Incredible 2 SIM Card Replacement: 手順 4、 2の画像 2
    • Gently lever the battery up and away from the lights.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
  5. HTC Incredible 2 SIM Card Replacement, SIM Card: 手順 5、 2の画像 1 HTC Incredible 2 SIM Card Replacement, SIM Card: 手順 5、 2の画像 2
    • Apply pressure with your fingertip to the pressure clip beneath the SIM card.
    • While keeping pressure on the clip, use another finger to gently slide the SIM card down over the clip.
  6. HTC Incredible 2 SIM Card Replacement: 手順 6、 2の画像 1 HTC Incredible 2 SIM Card Replacement: 手順 6、 2の画像 2
    • Keep sliding SIM card until completely free from holding apparatus. Now remove the SIM card.
終わりに
作成者
3人の作成者と共同で作成されました。
William Slope
メンバー登録日: 04/22/14
130 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 11-53, Amido Spring 2014 Cal Poly, Team 11-53, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S11G53
5 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 1,253
