メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HTC Hero Camera Replacement
必要な工具と部品
  1. HTC Hero Camera Replacement, Back Case: 手順 1、 1の画像 1
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
    FixBotに聞いてみる
  2. HTC Hero Camera Replacement: 手順 2、 1の画像 1
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
    FixBotに聞いてみる
  3. HTC Hero Camera Replacement: 手順 3、 1の画像 1
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
    FixBotに聞いてみる
  4. HTC Hero Camera Replacement: 手順 4、 2の画像 1 HTC Hero Camera Replacement: 手順 4、 2の画像 2
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
    FixBotに聞いてみる
  5. HTC Hero Camera Replacement, Camera: 手順 5、 3の画像 1 HTC Hero Camera Replacement, Camera: 手順 5、 3の画像 2 HTC Hero Camera Replacement, Camera: 手順 5、 3の画像 3
    • Locate the four metal tabs on the top and bottom of the camera holding the camera enclosure to the motherboard.
    FixBotに聞いてみる
  6. HTC Hero Camera Replacement: 手順 6、 2の画像 1 HTC Hero Camera Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    • Using a pair of metal tweezers, simultaneously depress both tabs on one side of the camera enclosure and gently pull up until tabs come free. Repeat for the opposite side.
    FixBotに聞いてみる
  7. HTC Hero Camera Replacement: 手順 7、 2の画像 1 HTC Hero Camera Replacement: 手順 7、 2の画像 2
    • Pull the released camera enclosure away from the motherboard until it is completely free.
    FixBotに聞いてみる
  8. HTC Hero Camera Replacement: 手順 8、 2の画像 1 HTC Hero Camera Replacement: 手順 8、 2の画像 2
    • Now with camera unit exposed, gently wiggle the camera as you pull away from the phone to remove it.
    FixBotに聞いてみる
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Max Brown
メンバー登録日: 01/23/12
139 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 3-26, Amido Winter 2012 Cal Poly, Team 3-26, Amido Winter 2012人のメンバー
CPSU-AMIDO-W12S3G26
5 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 59
今までの合計 1,631
