この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will help you get to the speaker, in case it needs to be replaced
必要な工具と部品
Carefully pull the rear cover from the back of the phone.
Place a finger beneath the small lip on the left side of the battery.
With the chassis removed, set down the phone and locate the speaker on the inside of the housing.
The speaker should be easily popped out of place with a small amount of force
ある他の人がこのガイドを完成しました。
