はじめに
This guide demonstrates how to propery remove and replace the front panel of an HTC HD 2.
  1. HTC HD 2 Touch Glas Repair
    • HTC HD 2 Touch Glas Repair
  2. Open the back cover and remove the battery.
    • Open the back cover and remove the battery.
  3. Use a small Philips screwdriver to remove the four indicated screws.
    • Use a small Philips screwdriver to remove the four indicated screws.
  4. Use a pry tool along the edges of the device to remove the broken or non-functional screen.
    • Use a pry tool along the edges of the device to remove the broken or non-functional screen.
  5. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  6. Carefully pull the flex cable connections. Carefully pull the flex cable connections. Carefully pull the flex cable connections.
    • Carefully pull the flex cable connections.
  7. Danach 3 tesa stripes lösen Using tweezers, release the 3 tesa strips. Using tweezers, release the 3 tesa strips.
    • Danach 3 tesa stripes lösen
    • Using tweezers, release the 3 tesa strips.
  8. Kabel vorsichtig aus dem Kabelschacht ... Carefully remove the cable from its shaft. Carefully remove the cable from its shaft.
    • Kabel vorsichtig aus dem Kabelschacht ...
    • Carefully remove the cable from its shaft.
  9. FLEX FLEX FLEX
    • FLEX
  10. Einzelnd Einzelnd Einzelnd
    • Einzelnd
  11. Flex Flex Flex
    • Flex
  12. Aufklappen Aufklappen Aufklappen
    • Aufklappen
  13. Vorsichtig
    • Vorsichtig
まとめ
Mark Kruhse
メンバー登録日: 2014年11月10日
19 ポイント
1ガイドが承認済み
統計データを表示:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 174
