この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If your Fortress' camera is malfunctioning and you've ruled out any software problems, you may want to install a new Camera.
In this guide, you'll learn how to install the HTC Fortress camera. This guide requires a moderate amount of dismantling of your phone with tools from the iFixit tool kit.
必要な工具と部品
Remove the camera panel by hand (black cover above the battery slot).
During reassembly, put the cable back in by holding the black piece slightly above its slot and using the spudger to gently press the end of the cable back into its fitting. Then, insert the black piece so it is flush with the black panel again.
ある他の人がこのガイドを完成しました。
