この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
In this guide, we will be removing and replacing the HTC EXCA100's screen
必要な工具と部品
Remove the rubber screw covers. If needed, use a thin object to help pry them off. There should be two of them on top of the phone. Skip this step if already removed.
Pry loose the metal cover near the camera lens, circled in the picture.
Remove the metal frame. Slip out the copper clips still attached to the bottom frame from the frame carefully.
もう少しです!
終わりに
