メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
Replacing a broken or unresponsive HTC EXCA100 Keyboard
  1. Remove the rubber screw covers. If needed, use a thin object to help pry them off. There should be two of them on top of the phone. Skip this step if already removed.
    • Remove the rubber screw covers. If needed, use a thin object to help pry them off. There should be two of them on top of the phone. Skip this step if already removed.
    • Pry loose the metal cover near the camera lens, circled in the picture.
  2. Remove the battery cover.
    • Remove the battery cover.
    • Gripping the battery by the bottom, lift and remove it from the phone.
  3. After removing the rubber stoppers on top, there should be six exposed screws. Remove these using the T6 screwdriver. Next, use the spudger to loosen the case underneath the shiny metal edge. Go all the way around the phone until completely loosened. The case is superglued on and will not permanently damage the phone when removed, but you should still use caution.
    • After removing the rubber stoppers on top, there should be six exposed screws. Remove these using the T6 screwdriver.
    • Next, use the spudger to loosen the case underneath the shiny metal edge. Go all the way around the phone until completely loosened.
    • The case is superglued on and will not permanently damage the phone when removed, but you should still use caution.
    • After loosening the case, remove it.
    • There is a wire that connects both the top and bottom of the case. If you are not careful when removing the case, you might snap the wire.
  4. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  5. Remove the one remaining screw in the logic board. Unclip the wire that connects the back of the case to the logic board.
    • Remove the one remaining screw in the logic board.
    • Unclip the wire that connects the back of the case to the logic board.
  6. On the left side of the phone, there are three copper colored clips. Unclip the bottom clip, thread the middle one through the logic board, and pull the top one out gently. You can then lift the logic board out of the phone.
    • On the left side of the phone, there are three copper colored clips.
    • Unclip the bottom clip, thread the middle one through the logic board, and pull the top one out gently.
    • You can then lift the logic board out of the phone.
    • Do this at an angle, lifting the side to the right of the SIM card instructions.
    • One of the strips is attached to the front of the case, and goes through the logic board. Be careful not to break this piece.
  7. Remove the metal frame. Slip out the copper clips still attached to the bottom frame from the frame carefully.
    • Remove the metal frame. Slip out the copper clips still attached to the bottom frame from the frame carefully.
  8. Remove the metal backing to the keyboard using Phillip 00 screwdriver to remove the 3 screws. After the screws are removed, take off the back cover of the keyboard. You can now peel off the keyboard, and replace it. After the new keyboard is in place, reassemble the device.
    • Remove the metal backing to the keyboard using Phillip 00 screwdriver to remove the 3 screws.
    • After the screws are removed, take off the back cover of the keyboard.
    • You can now peel off the keyboard, and replace it. After the new keyboard is in place, reassemble the device.
終わりに
Ian Mitchell
メンバー登録日: 2011年04月19日
142 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 25-27, Garner Spring 2011 Cal Poly, Team 25-27, Garner Spring 2011人のメンバー
CPSU-GARNER-S11S25G27
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,803
