メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HTC Evo 4G Rear Inner Frame Replacement
必要な工具と部品
  1. HTC Evo 4G Rear Inner Frame Replacement, Rear Panel: 手順 1、 1の画像 1
    • Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
    • Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
  2. HTC Evo 4G Rear Inner Frame Replacement: 手順 2、 1の画像 1
    • Lift the rear panel off of the inner rear frame.
  3. HTC Evo 4G Rear Inner Frame Replacement, Battery: 手順 3、 2の画像 1 HTC Evo 4G Rear Inner Frame Replacement, Battery: 手順 3、 2の画像 2
    • Using the tip of your finger, lift the battery from the end closest to the camera.
    • Remove the battery from the rear inner frame.
  4. HTC Evo 4G Rear Inner Frame Replacement, MicroSD card: 手順 4、 1の画像 1
    • Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
    • The retainer will move about 1 mm and stop. Do not attempt to completely remove the MicroSD card retainer.
  5. HTC Evo 4G Rear Inner Frame Replacement: 手順 5、 1の画像 1
    この手順で使用する道具:
    • Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
  6. HTC Evo 4G Rear Inner Frame Replacement, Rear Inner Frame: 手順 6、 1の画像 1
    • Remove six T5 Torx screws securing the rear inner frame to the inner case.
  7. HTC Evo 4G Rear Inner Frame Replacement: 手順 7、 1の画像 1
    • Gently insert an iPod opening tool between the rear inner frame and its plastic surround near the Micro HDMI port.
    • Carefully pry the top edge of the rear inner frame away from the front surround of the Evo.
  8. HTC Evo 4G Rear Inner Frame Replacement: 手順 8、 2の画像 1 HTC Evo 4G Rear Inner Frame Replacement: 手順 8、 2の画像 2
    • Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo.
  9. HTC Evo 4G Rear Inner Frame Replacement: 手順 9、 3の画像 1 HTC Evo 4G Rear Inner Frame Replacement: 手順 9、 3の画像 2 HTC Evo 4G Rear Inner Frame Replacement: 手順 9、 3の画像 3
    • Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo.
    • Pry up the rear inner frame along the right edge using the method described in previous steps.
    • Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
  10. HTC Evo 4G Rear Inner Frame Replacement: 手順 10、 1の画像 1
    • Remove the rear inner frame from the rest of the Evo.
終わりに
9 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Walter Galan
709,369 ポイント
1,203のガイドは作成済み
1件のガイドコメント
You may want people to also know they have to remove the lcd panel and the rear speaker to install them in their new rear inner panel.
Tony Stone - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 45
今までの合計 12,402
