はじめに
Use this guide to remove the rear inner frame and expose internal components.
必要な工具と部品
Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
Press the MicroSD card further into its slot until it clicks.
Release the MicroSD card, and it will pop out slightly.
ある他の人がこのガイドを完成しました。
