メインコンテンツにスキップ
HTC Droid Incredible Optical Joystick Replacement
必要な工具と部品
  1. HTC Droid Incredible Optical Joystick Replacement, Battery: 手順 1、 3の画像 1 HTC Droid Incredible Optical Joystick Replacement, Battery: 手順 1、 3の画像 2 HTC Droid Incredible Optical Joystick Replacement, Battery: 手順 1、 3の画像 3
    • Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
    • Useful tip: a penny or dime works in a pinch if you can't use your thumbnail.
    • Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
  2. HTC Droid Incredible Optical Joystick Replacement: 手順 2、 1の画像 1
    • Remove the rear panel from the phone.
  3. HTC Droid Incredible Optical Joystick Replacement: 手順 3、 3の画像 1 HTC Droid Incredible Optical Joystick Replacement: 手順 3、 3の画像 2 HTC Droid Incredible Optical Joystick Replacement: 手順 3、 3の画像 3
    • Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
  4. HTC Droid Incredible Optical Joystick Replacement, MicroSD card: 手順 4、 2の画像 1 HTC Droid Incredible Optical Joystick Replacement, MicroSD card: 手順 4、 2の画像 2
    • Press the MicroSD card further into its slot until it clicks.
    • Release the MicroSD card, and it will pop out slightly.
  5. HTC Droid Incredible Optical Joystick Replacement: 手順 5、 2の画像 1 HTC Droid Incredible Optical Joystick Replacement: 手順 5、 2の画像 2
    • Pull the MicroSD card straight out of its slot.
  6. HTC Droid Incredible Optical Joystick Replacement, Rear Inner Frame: 手順 6、 1の画像 1
    • Remove four T6 Torx screws securing the rear inner frame to the front case.
  7. HTC Droid Incredible Optical Joystick Replacement: 手順 7、 1の画像 1
    • The rear inner frame is attached to the front case by nine plastic clips, marked here for reference.
  8. HTC Droid Incredible Optical Joystick Replacement: 手順 8、 2の画像 1 HTC Droid Incredible Optical Joystick Replacement: 手順 8、 2の画像 2
    • Starting on the bottom of the phone, gently push in on the (red) rear inner frame behind each black clip with a small flathead screwdriver.
    • Go slow and be gentle, you may have to go back and forth between each side several times to work the rear inner case free.
  9. HTC Droid Incredible Optical Joystick Replacement: 手順 9、 2の画像 1 HTC Droid Incredible Optical Joystick Replacement: 手順 9、 2の画像 2
    • Loosen the clips on the side next to the camera using the method described in the previous step.
  10. HTC Droid Incredible Optical Joystick Replacement: 手順 10、 2の画像 1 HTC Droid Incredible Optical Joystick Replacement: 手順 10、 2の画像 2
    • Rotate the phone 180 degrees and loosen the three clips on the side by the speaker. Note that the middle clip on this side is smaller than the others.
  11. HTC Droid Incredible Optical Joystick Replacement: 手順 11、 3の画像 1 HTC Droid Incredible Optical Joystick Replacement: 手順 11、 3の画像 2 HTC Droid Incredible Optical Joystick Replacement: 手順 11、 3の画像 3
    • Use the same technique to loosen the clip on the top of the phone.
    • You may need to gently lift the bottom of the rear inner frame to free this clip.
  12. HTC Droid Incredible Optical Joystick Replacement: 手順 12、 2の画像 1 HTC Droid Incredible Optical Joystick Replacement: 手順 12、 2の画像 2
    • Remove the rear inner frame.
  13. HTC Droid Incredible Optical Joystick Replacement, Optical Joystick: 手順 13、 1の画像 1
    • Remove the tape covering the optical joystick ribbon cable.
  14. HTC Droid Incredible Optical Joystick Replacement: 手順 14、 2の画像 1 HTC Droid Incredible Optical Joystick Replacement: 手順 14、 2の画像 2
    • Flip the ZIF connector on the optical joystick cable.
    • Lift the optical joystick out of its socket.
    • Use a pair of tweezers to pull the optical joystick ribbon cable straight out of its socket.
  15. HTC Droid Incredible Optical Joystick Replacement: 手順 15、 3の画像 1 HTC Droid Incredible Optical Joystick Replacement: 手順 15、 3の画像 2 HTC Droid Incredible Optical Joystick Replacement: 手順 15、 3の画像 3
    • Remove the optical joystick.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Andrew Optimus Goldheart
メンバー登録日: 10/17/09
502,807 ポイント
407のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,767のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,418
