メインコンテンツにスキップ
HTC Droid Eris Motherboard Replacement
必要な工具と部品
  1. HTC Droid Eris Motherboard Replacement, Battery: 手順 1、 2の画像 1 HTC Droid Eris Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Place the device on a flat surface with the headphone outlet facing you.
    • Place the tip of one of your fingers over the highlighted spot.
    • Next, pull the back cover upwards. If this feels difficult, use the spudger.
  2. HTC Droid Eris Motherboard Replacement: 手順 2、 2の画像 1 HTC Droid Eris Motherboard Replacement: 手順 2、 2の画像 2
    • Lay the device on a flat surface with the screen facing downward. Use one hand to hold the device in place.
    • With your free hand, stick one of your fingers in the marked gap. Pull gently upwards towards you.
    • If the battery is not coming out with this technique, use the plastic opening tool.
  3. HTC Droid Eris Motherboard Replacement, Midframe: 手順 3、 2の画像 1 HTC Droid Eris Motherboard Replacement, Midframe: 手順 3、 2の画像 2
    • At the lower right hand corner of the phone use one hand to hold the device in place and use your finger to push the micro SD card inwards until you hear a "click" sound and it pops out.
    • If that method is difficult, use the plastic opening tool or spudger to push the micro SD card inwards and it will make a "click" sound and pop out.
  4. HTC Droid Eris Motherboard Replacement: 手順 4、 2の画像 1 HTC Droid Eris Motherboard Replacement: 手順 4、 2の画像 2
    • Use the T4 screwdriver to remove the three .05 mm screws from the back cover.
  5. HTC Droid Eris Motherboard Replacement: 手順 5、 2の画像 1 HTC Droid Eris Motherboard Replacement: 手順 5、 2の画像 2
    • Use the plastic opening tool and place it in the gap by the chrome bezels which are located on both sides of the device. Pull the plastic opening tool to pry plastic case apart. Start prying open the device and work around the seam of the phone in a clockwise direction.
    • DON’T BREAK THE CLIPS (you can damage the frame this way). Pry it gently until you hear it click and start to see it open.
    • Remove the midframe.
  6. HTC Droid Eris Motherboard Replacement, Motherboard: 手順 6、 2の画像 1 HTC Droid Eris Motherboard Replacement, Motherboard: 手順 6、 2の画像 2
    • With one hand holding the device in place, use your free hand to flip open the RF shield.
    • Peel the three pieces of silver metallic tape off of the logic board.
    • Do not peel off the two pieces of tape, that are located on the straightest edge of the RF shield closest to the edge of the phone.
    • Try not to damage the tape or the RF shield because they will need to be reused when reassembling the device.
  7. HTC Droid Eris Motherboard Replacement: 手順 7、 3の画像 1 HTC Droid Eris Motherboard Replacement: 手順 7、 3の画像 2 HTC Droid Eris Motherboard Replacement: 手順 7、 3の画像 3
    • Peel back the yellow tape. (located in the middle red highlighted box as shown)
    • When pulling off the tape make sure that you use your fingers to pull it up gently it has a connector attached to it (which is the light brown square on the top of the yellow tape) and the tape will be reused when reassembling the device.
    • Use your fingers to peel the two connectors on the sides away from the motherboard.
  8. HTC Droid Eris Motherboard Replacement: 手順 8、 3の画像 1 HTC Droid Eris Motherboard Replacement: 手順 8、 3の画像 2 HTC Droid Eris Motherboard Replacement: 手順 8、 3の画像 3
    • Unscrew the four 1.2mm Phillips screws with the Phillips #00 screwdriver from the motherboard.
    • Place the four screws in a safe place and then carefully lift up and remove the motherboard, then set it aside.
    • Take a note of the moisture indicator located in the yellow rectangle on the bottom of the device in the second picture. If the moisture indicator is red then the device has water damage.
終わりに
作成者
7人の作成者と共同で作成されました。
Elizabeth Ofori
メンバー登録日: 04/15/13
648 ポイント
6のガイドは作成済み
チーム
SUNY Cortland, Team 1-2, Getto Spring 2013 SUNY Cortland, Team 1-2, Getto Spring 2013人のメンバー
SUNYCORT-GETTO-S13S1G2
5 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 549
