メインコンテンツにスキップ
HTC Droid DNA Speaker Port Replacement
必要な工具と部品
  1. HTC Droid DNA Speaker Port Replacement, Remove the SIM Card Tray: 手順 1、 1の画像 1
    • Poke a paperclip into the hole to the right of the SIM Card Tray. The SIM Card Tray will automatically pop out.
  2. HTC Droid DNA Speaker Port Replacement, Removing the SIM Card Tray: 手順 2、 2の画像 1 HTC Droid DNA Speaker Port Replacement, Removing the SIM Card Tray: 手順 2、 2の画像 2
    • Pull out the SIM Card Tray with your fingers.
  3. HTC Droid DNA Speaker Port Replacement, Loosen the Phone Casing: 手順 3、 2の画像 1 HTC Droid DNA Speaker Port Replacement, Loosen the Phone Casing: 手順 3、 2の画像 2
    • Make sure the USB cover on the bottom of the phone is removed first.
    • Starting at a corner, slowly work your way around the edge of the sides with your prying tool to loosen the front panel.
    • Take your time. A lot of force is necessary to loosen the front panel.
  4. HTC Droid DNA Speaker Port Replacement, Pull the Casing Apart: 手順 4、 1の画像 1
    • Slowly pull the panel apart from the back of the phone.
    • Apply a moderate force to pry the panel from the back of the phone.
  5. HTC Droid DNA Speaker Port Replacement, Remove the Black Tape: 手順 5、 1の画像 1
    • Set the device down so that the bottom of the phone is facing to the right.
    • Gently take off the piece of black tape surrounding the motherboard.
    • Be careful not to rip the tape.
  6. HTC Droid DNA Speaker Port Replacement, Remove the Yellow Tape: 手順 6、 1の画像 1
    • Use your tweezers to take off the yellow tape on the bottom left corner of the phone.
  7. HTC Droid DNA Speaker Port Replacement: 手順 7、 1の画像 1
    • Rotate your phone 90 degrees clockwise so the bottom of the phone is facing you.
    • Use the T5 Torx screwdriver to remove the two 4mm screws located at the bottom of the phone.
  8. HTC Droid DNA Speaker Port Replacement, Remove the Void Screw: 手順 8、 1の画像 1
    • Use the Phillips #000 screwdriver to remove the single 2.7mm void screw on the bottom right.
  9. HTC Droid DNA Speaker Port Replacement, Remove the Screw Retaining Bracket: 手順 9、 1の画像 1
    • Rotate your phone back 90 Degrees counter-clockwise.
    • Use your tweezers to take off the small metal retaining bracket on the bottom right of the phone.
  10. HTC Droid DNA Speaker Port Replacement, Remove the Connector Screws: 手順 10、 1の画像 1
    • Remove the following Phillips #000 screws from the motherboard:
    • Four 1.6 mm screws
    • Two 1.5 mm screws
  11. HTC Droid DNA Speaker Port Replacement, Unfasten the Connectors: 手順 11、 2の画像 1 HTC Droid DNA Speaker Port Replacement, Unfasten the Connectors: 手順 11、 2の画像 2
    • Use your pry tool to unfasten the connectors on both sides of the motherboard.
    • The connectors will still be attached to the green camera board at the top so DO NOT try to pull them off or bend them severely.
  12. HTC Droid DNA Speaker Port Replacement, Remove the Yellow Tape: 手順 12、 1の画像 1
    • Use your tweezers to remove the two pieces of yellow tape shown.
  13. HTC Droid DNA Speaker Port Replacement, Flipping up the White Board: 手順 13、 2の画像 1 HTC Droid DNA Speaker Port Replacement, Flipping up the White Board: 手順 13、 2の画像 2
    • Use your tweezers to gently snap up the white board on the bottom right of the motherboard.
  14. HTC Droid DNA Speaker Port Replacement, Disconnect the Connector: 手順 14、 1の画像 1
    • Use your tweezers to disconnect the black connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cable of the Connector.
  15. HTC Droid DNA Speaker Port Replacement, Flipping up the White Board: 手順 15、 2の画像 1 HTC Droid DNA Speaker Port Replacement, Flipping up the White Board: 手順 15、 2の画像 2
    • Use your tweezers to gently snap the other white board on the bottom right of the motherboard up.
  16. HTC Droid DNA Speaker Port Replacement, Disconnect the Connector: 手順 16、 1の画像 1
    • Use your tweezers to disconnect the other small connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cables for the Connector.
  17. HTC Droid DNA Speaker Port Replacement, Flipping up the White Board: 手順 17、 2の画像 1 HTC Droid DNA Speaker Port Replacement, Flipping up the White Board: 手順 17、 2の画像 2
    • Rotate the phone 180 degrees.
    • Use your tweezers to gently snap up the white board on the top left of the motherboard.
  18. HTC Droid DNA Speaker Port Replacement, Disconnect the Connector: 手順 18、 1の画像 1
    • Use your tweezers to disconnect the cable on the top left of the motherboard.
  19. HTC Droid DNA Speaker Port Replacement, Flipping up the Black Board: 手順 19、 2の画像 1 HTC Droid DNA Speaker Port Replacement, Flipping up the Black Board: 手順 19、 2の画像 2
    • Use your tweezers to gently snap up the black board on the top left of the motherboard.
  20. HTC Droid DNA Speaker Port Replacement, Disconnect the Small Ribbon Connector: 手順 20、 1の画像 1
    • Use your tweezers to gently remove the yellow connector on the top left of the phone.
  21. HTC Droid DNA Speaker Port Replacement, Remove the Black Wire: 手順 21、 1の画像 1
    • Remove the long black wire on the left of the motherboard.
  22. HTC Droid DNA Speaker Port Replacement, Remove the Two Black Wires: 手順 22、 1の画像 1
    • Reorient the phone so that the green camera board is farthest from you.
    • Use your tweezers to remove the two wires located at the top of the board. The wires snap off very easily so not much force is needed.
  23. HTC Droid DNA Speaker Port Replacement, Remove the Screws: 手順 23、 1の画像 1
    • Use a Phillips #000 screwdriver to remove the two 3.9mm screws on top of motherboard.
  24. HTC Droid DNA Speaker Port Replacement, Remove the Motherboard: 手順 24、 2の画像 1 HTC Droid DNA Speaker Port Replacement, Remove the Motherboard: 手順 24、 2の画像 2
    • Now, use your fingers to slowly pull up the motherboard and remove it from the phone.
  25. HTC Droid DNA Speaker Port Replacement, Remove the Charging Port Assembly: 手順 25、 2の画像 1 HTC Droid DNA Speaker Port Replacement, Remove the Charging Port Assembly: 手順 25、 2の画像 2
    • Use the plastic prying tool to gently remove the charging port assembly.
  26. HTC Droid DNA Speaker Port Replacement, Disassemble Charging Port Assembly: 手順 26、 1の画像 1
    • Use a Phillips #000 screw driver to remove the single 2.1mm screw located on the backside of the assembly.
  27. HTC Droid DNA Speaker Port Replacement, Undo the Wire Connection: 手順 27、 2の画像 1 HTC Droid DNA Speaker Port Replacement, Undo the Wire Connection: 手順 27、 2の画像 2
    • Use your tweezers to undo the red and black wire connection.
  28. HTC Droid DNA Speaker Port Replacement, Separate the Black and Blue Assembly Pieces: 手順 28、 3の画像 1 HTC Droid DNA Speaker Port Replacement, Separate the Black and Blue Assembly Pieces: 手順 28、 3の画像 2 HTC Droid DNA Speaker Port Replacement, Separate the Black and Blue Assembly Pieces: 手順 28、 3の画像 3
    • Use the plastic prying tool to separate the assembly into two pieces: blue and black.
  29. HTC Droid DNA Speaker Port Replacement, Removing the speaker: 手順 29、 2の画像 1 HTC Droid DNA Speaker Port Replacement, Removing the speaker: 手順 29、 2の画像 2
    • Apply pressure to the grey side of the speaker with a blunt object to push out the speaker.
    • The speaker is stuck with adhesive so it will take a little bit of extra force.
終わりに
作成者
2人の作成者と共同で作成されました。
Sam Gallagher
メンバー登録日: 10/14/14
113 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 4-43, Amido Fall 2014 Cal Poly, Team 4-43, Amido Fall 2014人のメンバー
CPSU-AMIDO-F14S4G43
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,119
