Make sure the USB cover on the bottom of the phone is removed first.
Starting at a corner, slowly work your way around the edge of the sides with your prying tool to loosen the front panel.
Take your time. A lot of force is necessary to loosen the front panel.
Set the device down so that the bottom of the phone is facing to the right.
Gently take off the piece of black tape surrounding the motherboard.
Be careful not to rip the tape.
Use your pry tool to unfasten the connectors on both sides of the motherboard.
The connectors will still be attached to the green camera board at the top so DO NOT try to pull them off or bend them severely.
Reorient the phone so that the green camera board is farthest from you.
Use your tweezers to remove the two wires located at the top of the board. The wires snap off very easily so not much force is needed.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
