メインコンテンツにスキップ
HTC Droid DNA Battery Replacement
必要な工具と部品
  1. HTC Droid DNA Battery Replacement, Remove the SIM Card Tray: 手順 1、 1の画像 1
    • Poke a paperclip into the hole to the right of the SIM Card Tray. The SIM Card Tray will automatically pop out.
  2. HTC Droid DNA Battery Replacement, Removing the SIM Card Tray: 手順 2、 2の画像 1 HTC Droid DNA Battery Replacement, Removing the SIM Card Tray: 手順 2、 2の画像 2
    • Pull out the SIM Card Tray with your fingers.
  3. HTC Droid DNA Battery Replacement, Loosen the Phone Casing: 手順 3、 2の画像 1 HTC Droid DNA Battery Replacement, Loosen the Phone Casing: 手順 3、 2の画像 2
    • Make sure the USB cover on the bottom of the phone is removed first.
    • Starting at a corner, slowly work your way around the edge of the sides with your prying tool to loosen the front panel.
    • Take your time. A lot of force is necessary to loosen the front panel.
  4. HTC Droid DNA Battery Replacement, Pull the Casing Apart: 手順 4、 1の画像 1
    • Slowly pull the panel apart from the back of the phone.
    • Apply a moderate force to pry the panel from the back of the phone.
  5. HTC Droid DNA Battery Replacement, Remove the Black Tape: 手順 5、 1の画像 1
    • Set the device down so that the bottom of the phone is facing to the right.
    • Gently take off the piece of black tape surrounding the motherboard.
    • Be careful not to rip the tape.
    This tape wasn't present on my phone
    Gerry Lingner - 返信
  6. HTC Droid DNA Battery Replacement, Remove the Yellow Tape: 手順 6、 1の画像 1
    • Use your tweezers to take off the yellow tape on the bottom left corner of the phone.
    Needed T4 Torx driver for this, not T5, on my phone.
    Gerry Lingner - 返信
  7. HTC Droid DNA Battery Replacement: 手順 7、 1の画像 1
    • Rotate your phone 90 degrees clockwise so the bottom of the phone is facing you.
    • Use the T5 Torx screwdriver to remove the two 4mm screws located at the bottom of the phone.
  8. HTC Droid DNA Battery Replacement, Remove the Void Screw: 手順 8、 1の画像 1
    • Use the Phillips #000 screwdriver to remove the single 2.7mm void screw on the bottom right.
    Note that, in the picture, there is a hole under the connector which rests over the yellow tape removed in step 7. There may be a screw in that hole which is opposite the screw removed in step 8. You may also have a different void screw toward the bottom-left of the phone.
    cmbarona - 返信
  9. HTC Droid DNA Battery Replacement, Remove the Screw Retaining Bracket: 手順 9、 1の画像 1
    • Rotate your phone back 90 Degrees counter-clockwise.
    • Use your tweezers to take off the small metal retaining bracket on the bottom right of the phone.
  10. HTC Droid DNA Battery Replacement, Remove the Connector Screws: 手順 10、 1の画像 1
    • Remove the following Phillips #000 screws from the motherboard:
    • Four 1.6 mm screws
    • Two 1.5 mm screws
  11. HTC Droid DNA Battery Replacement, Unfasten the Connectors: 手順 11、 2の画像 1 HTC Droid DNA Battery Replacement, Unfasten the Connectors: 手順 11、 2の画像 2
    • Use your pry tool to unfasten the connectors on both sides of the motherboard.
    • The connectors will still be attached to the green camera board at the top so DO NOT try to pull them off or bend them severely.
  12. HTC Droid DNA Battery Replacement, Remove the Yellow Tape: 手順 12、 1の画像 1
    • Use your tweezers to remove the two pieces of yellow tape shown.
  13. HTC Droid DNA Battery Replacement, Flipping up the White Board: 手順 13、 2の画像 1 HTC Droid DNA Battery Replacement, Flipping up the White Board: 手順 13、 2の画像 2
    • Use your tweezers to gently snap up the white board on the bottom right of the motherboard.
  14. HTC Droid DNA Battery Replacement, Disconnect the Connector: 手順 14、 1の画像 1
    • Use your tweezers to disconnect the black connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cable of the Connector.
  15. HTC Droid DNA Battery Replacement, Flipping up the White Board: 手順 15、 2の画像 1 HTC Droid DNA Battery Replacement, Flipping up the White Board: 手順 15、 2の画像 2
    • Use your tweezers to gently snap the other white board on the bottom right of the motherboard up.
  16. HTC Droid DNA Battery Replacement, Disconnect the Connector: 手順 16、 1の画像 1
    • Use your tweezers to disconnect the other small connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cables for the Connector.
  17. HTC Droid DNA Battery Replacement, Flipping up the White Board: 手順 17、 2の画像 1 HTC Droid DNA Battery Replacement, Flipping up the White Board: 手順 17、 2の画像 2
    • Rotate the phone 180 degrees.
    • Use your tweezers to gently snap up the white board on the top left of the motherboard.
  18. HTC Droid DNA Battery Replacement, Disconnect the Connector: 手順 18、 1の画像 1
    • Use your tweezers to disconnect the cable on the top left of the motherboard.
  19. HTC Droid DNA Battery Replacement, Flipping up the Black Board: 手順 19、 2の画像 1 HTC Droid DNA Battery Replacement, Flipping up the Black Board: 手順 19、 2の画像 2
    • Use your tweezers to gently snap up the black board on the top left of the motherboard.
  20. HTC Droid DNA Battery Replacement, Disconnect the Small Ribbon Connector: 手順 20、 1の画像 1
    • Use your tweezers to gently remove the yellow connector on the top left of the phone.
  21. HTC Droid DNA Battery Replacement, Remove the Black Wire: 手順 21、 1の画像 1
    • Remove the long black wire on the left of the motherboard.
  22. HTC Droid DNA Battery Replacement, Remove the Two Black Wires: 手順 22、 1の画像 1
    • Reorient the phone so that the green camera board is farthest from you.
    • Use your tweezers to remove the two wires located at the top of the board. The wires snap off very easily so not much force is needed.
    Had additional screw to remove here at bottom of phone opposite location of Void screw
    Gerry Lingner - 返信
  23. HTC Droid DNA Battery Replacement, Remove the Screws: 手順 23、 1の画像 1
    • Use a Phillips #000 screwdriver to remove the two 3.9mm screws on top of motherboard.
  24. HTC Droid DNA Battery Replacement, Remove the Motherboard: 手順 24、 2の画像 1 HTC Droid DNA Battery Replacement, Remove the Motherboard: 手順 24、 2の画像 2
    • Now, use your fingers to slowly pull up the motherboard and remove it from the phone.
  25. HTC Droid DNA Battery Replacement, Separate the Housing: 手順 25、 1の画像 1
    • Use the pry tool to separate the housing of the phone from the battery.
    • Try not to damage the adhesive holding the battery.
    • The adhesive holding the battery in place is very strong. Use the pry tool in multiple spots around the battery to loosen the adhesive.
  26. HTC Droid DNA Battery Replacement, Remove the Battery: 手順 26、 2の画像 1 HTC Droid DNA Battery Replacement, Remove the Battery: 手順 26、 2の画像 2
    • Slowly pull up the battery with the prying tool.
    • Remove the battery with your fingers.
    • Try to keep the black paper in place around the battery. However, should it rip, that is okay.
終わりに
16 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Madeline Tran
メンバー登録日: 10/14/14
707 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 4-43, Amido Fall 2014 Cal Poly, Team 4-43, Amido Fall 2014人のメンバー
CPSU-AMIDO-F14S4G43
4 メンバー
10のガイドは作成済み
2 件のコメント
Will the replacement battery need adhesive for it? Or will the adhesive still be there on the bottom of the phone? Thanks!
Adam - 返信
Thanks for posting this hope I now get a few more years out of my DNA for not much money.
Gerry Lingner - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 17,324
