はじめに
The volume buttons are commonly known for having issues. Luckily the repair is fairly easy to complete. This guide will take you step by step on how to replace the volume buttons.
必要な工具と部品
Pry open the back panel by inserting the plastic opening tool on the left of the camera. We find this spot the easiest to get the tool under the panel.
Using the T5 screw driver, unscrew the four screws that are holding down the black plastic casing.
ある他の人がこのガイドを完成しました。
