はじめに
First, it is necessary to ensure that the bottom speaker is faulty before replacement. Confirm that this is the case by testing it via a phone call followed by testing the microphone recording application on the phone. If the speaker does not work in both of these cases, it is likely damaged and in need of replacement. The procedure will be presented step-wise to ensure that none of the hardware is damaged, as this guide involves the removal of fragile components.
パーツ
パーツは指定されていません。
Pry the back panel of the screen using the plastic opener.
Work your way gently around the device, using picks as necessary to keep the back panel separated.
Disconnect wire going from the printed circuit board to the motherboard using the tweezers.
3 の人々がこのガイドを完成させました。
