メインコンテンツにスキップ
HTC Desire 626s Charging Port Replacement
必要な工具と部品
  1. HTC Desire 626s Charging Port Replacement, Backplate: 手順 1、 3の画像 1 HTC Desire 626s Charging Port Replacement, Backplate: 手順 1、 3の画像 2 HTC Desire 626s Charging Port Replacement, Backplate: 手順 1、 3の画像 3
    • Insert plastic opening tool in between the back cover and grey plastic.
    • Gently work your way around the phone while sliding the tool.
    • Gently pry on plastic cover as needed to release fasteners.
  2. HTC Desire 626s Charging Port Replacement: 手順 2、 2の画像 1 HTC Desire 626s Charging Port Replacement: 手順 2、 2の画像 2
    • There are 7 screws you need to remove before prying the secondary cover off. You will need to use the JIS #000 screwdriver and the T5 Torx screwdriver to remove these screws.
    • There is a screw under the "void" sticker.
  3. HTC Desire 626s Charging Port Replacement: 手順 3、 2の画像 1 HTC Desire 626s Charging Port Replacement: 手順 3、 2の画像 2
    • Once the screws are removed, use the plastic opening tool to remove the remaining plastic cover.
    • Start from the corners of the phone, and insert the plastic opening tool between the outer colored rim and the screen.
    • This portion of the cover will be more difficult to remove than the initial back cover. Be patient and gentle around the button holes.
  4. HTC Desire 626s Charging Port Replacement, Battery: 手順 4、 1の画像 1
    • By using the angled tweezers, you have to be careful when you try to remove the battery connection by start pulling the wires.
  5. HTC Desire 626s Charging Port Replacement: 手順 5、 1の画像 1
    • Using the plastic opening tool to separate the battery and remove it.
  6. HTC Desire 626s Charging Port Replacement: 手順 6、 1の画像 1
    • Pull the battery out
  7. HTC Desire 626s Charging Port Replacement, Charging Port: 手順 7、 2の画像 1 HTC Desire 626s Charging Port Replacement, Charging Port: 手順 7、 2の画像 2
    • Using tweezers, peel back the plastic as shown in these two pictures.
    • You will need to pull it back as shown in picture 2 for future steps.
  8. HTC Desire 626s Charging Port Replacement: 手順 8、 1の画像 1
    • Flip the white plastic piece up to a 90 degree angle.
    • Do this by using tweezers to grab the plastic, then gently lifting into position.
  9. HTC Desire 626s Charging Port Replacement: 手順 9、 1の画像 1
    • Carefully lift the circuit board up and out.
    • Removal was easy with just fingers, but tweezers may be needed if there is resistance.
  10. HTC Desire 626s Charging Port Replacement: 手順 10、 3の画像 1 HTC Desire 626s Charging Port Replacement: 手順 10、 3の画像 2 HTC Desire 626s Charging Port Replacement: 手順 10、 3の画像 3
    • Now that the circuit board is detached, the connecting wire needs to be removed.
    • Grasp the wire as shown in picture 2 at the red circle.
    • Pull straight up, perpendicular to the board. The wire pops off easily.
    • Tweezers may be used in place of fingers if you can not get a hold of this small wire and its connection.
  11. HTC Desire 626s Charging Port Replacement: 手順 11、 1の画像 1
    • The new board will not go in as easily as the old one came out. Just be patient and squeeze the edges to clip it into place.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Blake Bartlett
メンバー登録日: 04/03/19
732 ポイント
6のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 12
今までの合計 760
