メインコンテンツにスキップ
HTC Desire 310 Micro USB Port Replacement
必要な工具と部品
    • The video guide will show you how to replace the micro usb port properly. Repeat each step shown in the recording to complete the repair.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Alex Sander
メンバー登録日: 02/28/17
38,867 ポイント
201のガイドは作成済み
4 件のコメント
Can’t see a blasted thing clearly. How do you make the pin connections on the motherboard?
Keith Weisberger - 返信
Hello! Please be more precise, the pin connections are already on the motherboard, if you haven’t got one you’ve probably tear them down.
Alex Sander -
Can barely see anything. Camera lense is filthy, picture not in focus and dark. How do you make the pin connections? it appears that you do so only after soldering the rear legs to the motherboard, but I can’t see how you manage it
It would be nice if you had explained what you were doing during the removal. What was that goo you put on it and how did it work to remove the old part?
andrew - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 23
今までの合計 784
