はじめに
The loudspeaker is located within the back panel of the device. This makes it relatively simple to access.
必要な工具と部品
Gently press the Release Button located at the bottom of the phone in order to remove the back panel of the device.
Use the Torx T5 screwdriver to remove the 7 Torx Screws (3mm) attached to the back housing of the device.
Turn the back panel over to access its interior, and locate the loudspeaker marked in the picture.
Remove it by gently pulling with the precision tweezers.
ある他の人がこのガイドを完成しました。
