メインコンテンツにスキップ
HTC Amaze Loud Speaker Replacement
必要な工具と部品
  1. HTC Amaze Loud Speaker Replacement, Battery: 手順 1、 2の画像 1 HTC Amaze Loud Speaker Replacement, Battery: 手順 1、 2の画像 2
    • Gently press the Release Button located at the bottom of the phone in order to remove the back panel of the device.
  2. HTC Amaze Loud Speaker Replacement: 手順 2、 1の画像 1
    • Once you locate the battery, look for a notch below it.
    • Gently insert your fingernails into the notch.
    • Lift the battery out of its recess.
  3. HTC Amaze Loud Speaker Replacement, HTC Amaze Back Panel Disassembly: 手順 3、 3の画像 1 HTC Amaze Loud Speaker Replacement, HTC Amaze Back Panel Disassembly: 手順 3、 3の画像 2 HTC Amaze Loud Speaker Replacement, HTC Amaze Back Panel Disassembly: 手順 3、 3の画像 3
    • Use the Torx T5 screwdriver to remove the 7 Torx Screws (3mm) attached to the back housing of the device.
    • One of the Screws may have a tape attached to it that says void. Removing this screw will void the devices warranty.
  4. HTC Amaze Loud Speaker Replacement: 手順 4、 3の画像 1 HTC Amaze Loud Speaker Replacement: 手順 4、 3の画像 2 HTC Amaze Loud Speaker Replacement: 手順 4、 3の画像 3
    • Proceed to remove the back housing by using the spudger to gently unclip each clip holding the back housing in place and then lift the outer edges of the back housing
    • If you're having trouble opening the back try using the spudger to gently pry all around the panel before you attempt to remove it.
  5. HTC Amaze Loud Speaker Replacement: 手順 5、 2の画像 1 HTC Amaze Loud Speaker Replacement: 手順 5、 2の画像 2
    • Now simply remove the back panel by gently pulling. This will make it easier to access the devices internal components.
  6. HTC Amaze Loud Speaker Replacement, Loud Speaker: 手順 6、 3の画像 1 HTC Amaze Loud Speaker Replacement, Loud Speaker: 手順 6、 3の画像 2 HTC Amaze Loud Speaker Replacement, Loud Speaker: 手順 6、 3の画像 3
    • Turn the back panel over to access its interior, and locate the loudspeaker marked in the picture.
    • Remove it by gently pulling with the precision tweezers.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Akshat Shah
メンバー登録日: 09/26/16
368 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 16-3, Eyestone Fall 2016 USF Tampa, Team 16-3, Eyestone Fall 2016人のメンバー
USFT-EYESTONE-F16S16G3
2 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 128
