この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If the CPU fan becomes to filled with dust or stops spinning, it must be replaced immediately. If it is not replaced then the CPU or motherboard can become damaged and cause the computer to be unbootable
必要な工具と部品
Lay the tower down carefully on its right side, with the vents pointing up.
To reassemble your device, follow these instructions in reverse order. Now you should feel confident replacing the CPU fan in your HP desktop without any difficulties.
2 の人々がこのガイドを完成させました。
