メインコンテンツにスキップ
HP w2216h Video Port Board Replacement
必要な工具と部品
  1. HP w2216h Video Port Board Replacement, Screen: 手順 1、 1の画像 1
    • 'Make sure you are grounded, the power supply is not connected and you are wearing safety goggles.
    • Use the Philips #000 screwdriver to remove the 4 round12mm screws on the back panel.
  2. HP w2216h Video Port Board Replacement: 手順 2、 2の画像 1 HP w2216h Video Port Board Replacement: 手順 2、 2の画像 2
    • Using a Philips #000 head remove 2 flat 12 mm screws above stand mounting bracket.
    • Using a PH1 Philips head with the 150 mm flexible extension remove 1 Philips head screw under the stand mounting bracket.
    • Stand will easily pull off.
  3. HP w2216h Video Port Board Replacement: 手順 3、 3の画像 1 HP w2216h Video Port Board Replacement: 手順 3、 3の画像 2 HP w2216h Video Port Board Replacement: 手順 3、 3の画像 3
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  4. HP w2216h Video Port Board Replacement: 手順 4、 3の画像 1 HP w2216h Video Port Board Replacement: 手順 4、 3の画像 2 HP w2216h Video Port Board Replacement: 手順 4、 3の画像 3
    • Be careful of the wires attaching the power button and the control buttons. Show extreme caution to ensure the button is not damaged.
    • Lift the screen assembly from the plastic housing from the corners.
  5. HP w2216h Video Port Board Replacement: 手順 5、 2の画像 1 HP w2216h Video Port Board Replacement: 手順 5、 2の画像 2
    • Remove the 4 connectors from the left side of the monitor on the back.
  6. HP w2216h Video Port Board Replacement: 手順 6、 3の画像 1 HP w2216h Video Port Board Replacement: 手順 6、 3の画像 2 HP w2216h Video Port Board Replacement: 手順 6、 3の画像 3
    • Lift the gray tape of the top of the monitor to expose the ribbon cable.
    • Remove the ribbon cable by sliding the connector towards the center of the screen assembly.
    • Lift the reflective tape next to the gray tape.
  7. HP w2216h Video Port Board Replacement: 手順 7、 3の画像 1 HP w2216h Video Port Board Replacement: 手順 7、 3の画像 2 HP w2216h Video Port Board Replacement: 手順 7、 3の画像 3
    • Remove the 4 PH1 8mm Philips round screws on the outer edge of the screen's assembly.
    • Lift the screen from the screen assembly.
  8. HP w2216h Video Port Board Replacement, Speakers: 手順 8、 1の画像 1
    • Remove the tape holding each speakers wire to the screen assembly.
  9. HP w2216h Video Port Board Replacement: 手順 9、 2の画像 1 HP w2216h Video Port Board Replacement: 手順 9、 2の画像 2
    • Remove the two 8mm Philips #000 head screws on each speaker.
  10. HP w2216h Video Port Board Replacement: 手順 10、 2の画像 1 HP w2216h Video Port Board Replacement: 手順 10、 2の画像 2
    • Remove the speakers by lifting them vertically from the screen assembly.
  11. HP w2216h Video Port Board Replacement: 手順 11、 1の画像 1
    • Remove the cables that connects the speakers to the signal output board.
  12. HP w2216h Video Port Board Replacement, Video Port Board: 手順 12、 1の画像 1
    • Remove the single Phillips #000 head screw above the HDMI port .
  13. HP w2216h Video Port Board Replacement: 手順 13、 1の画像 1
    • Remove the two 2.5mm hex screws on either side of the VGA port
  14. HP w2216h Video Port Board Replacement: 手順 14、 3の画像 1 HP w2216h Video Port Board Replacement: 手順 14、 3の画像 2 HP w2216h Video Port Board Replacement: 手順 14、 3の画像 3
    • Remove all 8mm Phillips #000 screws holding the board in place.
    • Remove the ribbon cable towards the bottom of the board by sliding the cable away from the board.
    • Remove both wire busses still on the board.
  15. HP w2216h Video Port Board Replacement: 手順 15、 1の画像 1
    • Lift the board out of the screen assembly by first pulling the board away from the wall where the ports mount, then upward.
終わりに
作成者
3人の作成者と共同で作成されました。
Branflakes222
メンバー登録日: 03/25/16
396 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-1, Miles Spring 2016 UMass Dartmouth, Team 1-1, Miles Spring 2016人のメンバー
UMASSD-MILES-S16S1G1
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 456
