この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The iOS is the original firmware on the motherboard. In some cases the computer can malfunction due to errors in the iOS setting. This error can be fixed by resetting the iOS.
Make sure the computer is unplugged.
Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
Set the desktop down horizontally with the front side facing you.
Press tab on the left side of the battery with your finger to release the battery from its position.
The battery should pop up out off its socket easily.
Once the battery has been removed, the BIOS is reset. Replace the battery back into its socket to complete the reset.
ある他の人がこのガイドを完成しました。
2 件のコメント
Hello.
I followed the above steps on an HP rp5700 desktop. Now the computer time and date is set back to 2000. I have entered setup to change date and time. However, the date and time does not change as I navigate date and time…. no change at all. I have changed this before on other rp5700 desktops but this just wont change.
Someone out there HELP.
Regards.
Turk.
I did this for my HP rp5700 desktop, but it did not remedy my situation of after start-up, my icons do not show up. Just a blue windows logo screen. The start button is visible, along with the date/time, but nothing else. Let it sit overnight and the same thing is shown the next morning. Is this Windows Explorer related? If so, what can I do to fix it?
