はじめに
In order to gain access to the CPU, the heat-sink must be removed first. Once the heat-sink is disconnected from the motherboard, the CPU will be exposed with thermal paste on the top of the CPU and the bottom of the heat-sink.
Use this link when applying the thermal paste to the replacement part. 放熱グリスの塗布方法
必要な工具と部品
Make sure the computer is unplugged.
Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
Set the desktop down horizontally with the front side facing you.
Using your hand, grip the Optical Drive and lift it up into a 45 degree angle.
Using your right index finger, press the tab with the green sticker located underneath the power supply.
While pressing the tab, lift up the power supply the same way you lifted up the optical drive.
Remove the two cables on the motherboard by grasping the cables with your hand and pulling the cables up and out.
Repeat the same process to remove the internal card power cable.
This is the same process as preformed when you previously removed the power cables from the optical drive and the hard drive.
Some cables may have small clips securing them in place. If so, be sure to press these clips inward using your fingers before pulling them out.
Using a Torx-Security T-15 screw driver, loosen the screws a little at a time evenly on each screw (process described below):
This process is done by slightly unscrewing a screw at one corner and moving to the screw at the diagonal corner next to unscrew slightly.
Then move to the opposite corners and repeat the process.
Continue until all of the screw are completely removed.
To reassemble your device, follow these instructions in reverse order. The only exception is to apply thermo paste on top of the CPU before putting the heat sink back on.
4 の人々がこのガイドを完成させました。
