メインコンテンツにスキップ
HP pavilion 15-cs3073cl Disassembly
必要な工具と部品
  1. HP pavilion 15-cs3073cl Disassembly, Remove front screws: 手順 1、 1の画像 1
    • Begin by removing the 3 screws on the bottom front of the laptop. A Phillips #00 works well here.
  2. HP pavilion 15-cs3073cl Disassembly, Remove hidden screws: 手順 2、 2の画像 1 HP pavilion 15-cs3073cl Disassembly, Remove hidden screws: 手順 2、 2の画像 2
    • There are 3 screws hidden under the rubber pads. Using a pry tool or something thin like a credit card to remove the glued on rubber pads you will find one screw on the left back and 2 under the right pad. Phillips #0 works well to remove these larger screws.
  3. HP pavilion 15-cs3073cl Disassembly, Pry the upper and lower body: 手順 3、 1の画像 1
    • With a thin pry bar or credit card push in between the upper and lower parts of the body and you'll hear a clicking sound as the tabs release the 2 pieces. Go all around the laptop until the bottom cover is completely off.
  4. HP pavilion 15-cs3073cl Disassembly, HDD removal: 手順 4、 1の画像 1
    • If you're upgrading the HDD remove the 2 screws on the exposed side and lift from that side. The other side is being held by 2 rubber nipples on a thin rubber strip that will bend as you pull the drive.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Josue Nolasco
メンバー登録日: 01/13/17
226 ポイント
1ガイドが承認済み
チーム
Green Shield Technology Green Shield Technology人のメンバー
Business
2 メンバー
1のガイドは作成済み
3 件のコメント
Good day,
Can we have the part number?
Cate Ledezma - 返信
Hello, I’m not sure what part number you’re looking for. These instructions are for the disassembly of the laptop as stated in the title. Once disassembled, you can replace any parts you need.
Josue Nolasco - 返信
This disassembly guide seems to only have the removal of the bottom cover and HDD, did I miss steps somewhere? Thanks!
John Doe - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 64
過去 30 日: 183
今までの合計 5,028
