メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
パーツ
パーツは指定されていません。
  1. Slide the silver release tab up and simultaneously lift the cover up from the left side.
    • Slide the silver release tab up and simultaneously lift the cover up from the left side.
  2. Push the tab from left to right to remove the cover.
    • Push the tab from left to right to remove the cover.
  3. Now lift the battery up and away from the device to remove it.
    • Now lift the battery up and away from the device to remove it.
  4. Remove the four silver screws (T5 x .25 in).
    • Remove the four silver screws (T5 x .25 in).
  5. Remove the single black screw (T5 x .125 in) beneath the HP sticker.
    • Remove the single black screw (T5 x .125 in) beneath the HP sticker.
  6. Next, use your plastic removal tool to separate the gray back from the black center piece. For better results, start the separation at the corner piece.
    • Next, use your plastic removal tool to separate the gray back from the black center piece.
    • For better results, start the separation at the corner piece.
  7. Remove the back case.
    • Remove the back case.
  8. Now that the back cover is removed, remove the small screw (#00 Philips x .17) to the left of the SD card slot
    • Now that the back cover is removed, remove the small screw (#00 Philips x .17) to the left of the SD card slot
  9. Next you will need to unlock and remove the ribbon cable Carefully pull back on both sides of the brown bar using metal tweezers, unlocking the cable and slipping it out of the connector
    • Next you will need to unlock and remove the ribbon cable
    • Carefully pull back on both sides of the brown bar using metal tweezers, unlocking the cable and slipping it out of the connector
    • The bar, connector, and cable are fragile components that can be easily broken
  10. Next you need to remove the wire off the bottom of the mother board The easiest method is to use some metal tweezers and grip the plug close to the connector.
    • Next you need to remove the wire off the bottom of the mother board
    • The easiest method is to use some metal tweezers and grip the plug close to the connector.
    • Make sure all these connections are properly disconnected before separation of the motherboard
  11. Next use your plastic removal tool and separate the silver front case from the black frame.
    • Next use your plastic removal tool and separate the silver front case from the black frame.
  12. Remove the 4 screws along the bottom of the faceplate
    • Remove the 4 screws along the bottom of the faceplate
    • They are #00 Philips head screws
  13. Once removed you can easily separate the keys from the body. Once removed you can easily separate the keys from the body.
    • Once removed you can easily separate the keys from the body.
終わりに
ある他の人がこのガイドを完成しました。
John Pagliero
メンバー登録日: 2011年01月27日
927 ポイント
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 309
