この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
必要な工具と部品
While sliding the silver release tab up, simultaneously lift the cover up from the left side.
Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
Now that the front cover is removed we will need to disconnect the LCD screen from the mother board. Pull the LCD connection out of the slot to properly disconnect.
ある他の人がこのガイドを完成しました。
