Next, use your plastic removal tool to separate the gray back from the black center piece.
For better results, start the separation at the corner piece.
Next, unlock and remove the ribbon cable.
Using metal tweezers, carefully pull back on both sides of the brown bar unlocking the cable and slipping it out of the connector.
The bar, the connector, and the cable are fragile components that are easily broken.
Next, remove the wire from the bottom of the mother board.
The easiest method is to use metal tweezers and grip the plug closest to the connector.
Make sure all the connections are properly disconnected before separation from the motherboard.
Now that the front cover is removed we can detach the screen
Remove the ribbon connector by pulling gently on the silver top. It will snap off the mother board.
The ribbon cable and connector can be easily removed if you genetly lift up the motherboard to create a small gap
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
