この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
必要な工具と部品
While sliding the silver release tab up, simultaneously lift the cover up from the left side.
Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
Now that the front cover is removed we can detach the screen
Remove the ribbon connector by pulling gently on the silver top. It will snap off the mother board.
ある他の人がこのガイドを完成しました。
