はじめに
Is your screen for your HP iPAQ H3850 cracked or not working? Don't worry, you can easily replace the screen using this guide.
The screen is a component that lets you see what you are doing on the iPAQ. It might be hard to see what is happening on the screen if it is cracked.
Before beginning this repair, make sure that the iPAQ is turned off.
必要な工具と部品
To begin the disassembly of the device, place it on a flat surface with the screen facing down.
ある他の人がこのガイドを完成しました。
