メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP iPAQ H3850 Screen Replacement
必要な工具と部品
  1. HP iPAQ H3850 Screen Replacement, Screen: 手順 1、 1の画像 1
    • To begin the disassembly of the device, place it on a flat surface with the screen facing down.
    FixBotに聞いてみる
  2. HP iPAQ H3850 Screen Replacement: 手順 2、 1の画像 1
    • Remove the four screws found on the back cover of the device.
    FixBotに聞いてみる
  3. HP iPAQ H3850 Screen Replacement: 手順 3、 1の画像 1
    • Carefully remove the back cover using the spudger against the grooves along the sides of the iPAQ.
    FixBotに聞いてみる
  4. HP iPAQ H3850 Screen Replacement: 手順 4、 1の画像 1
    • At this point, a yellow ribbon will be connecting both the front and back panels of the device. Carefully use the plastic opening tool to detach the ribbon from the connector pins.
    FixBotに聞いてみる
  5. HP iPAQ H3850 Screen Replacement: 手順 5、 1の画像 1
    • Remove SD card on top of device by pushing and then releasing.
    FixBotに聞いてみる
  6. HP iPAQ H3850 Screen Replacement: 手順 6、 1の画像 1
    • Remove the ribbon cable connected to display logic board by pulling the plastic clips on both sides towards top of device.
    • Use plastic opening tool to carefully pull brown ribbon cable from connector.
    FixBotに聞いてみる
  7. HP iPAQ H3850 Screen Replacement: 手順 7、 3の画像 1 HP iPAQ H3850 Screen Replacement: 手順 7、 3の画像 2 HP iPAQ H3850 Screen Replacement: 手順 7、 3の画像 3
    • Use the plastic opening tool to carefully remove the display logic board from its housing.
    • Unplug connector from the opposite end of the display logic board.
    • Completely remove component.
    FixBotに聞いてみる
  8. HP iPAQ H3850 Screen Replacement: 手順 8、 1の画像 1
    • Flip up black plastic clip on large ribbon cable connector located towards center of mother board.
    • Use plastic opening tool to carefully remove ribbon cable from connector.
    FixBotに聞いてみる
  9. HP iPAQ H3850 Screen Replacement: 手順 9、 1の画像 1
    この手順で使用する道具:
    • Locate clear/grey ribbon cable in bottom corner of device.
    • Gently pry cable out of connector with plastic opening tool.
    • Use hands or tweezers to remove if necessary.
    FixBotに聞いてみる
  10. HP iPAQ H3850 Screen Replacement: 手順 10、 1の画像 1
    • Use your hands to gently unplug the speaker and microphone connectors from the mother board.
    FixBotに聞いてみる
  11. HP iPAQ H3850 Screen Replacement: 手順 11、 1の画像 1
    • Remove three small screws from each corner of the motherboard using phillips head screwdriver.
    • Use your hands/plastic opening tool to carefully lift the mother board out of housing.
    • Place the motherboard to the side.
    FixBotに聞いてみる
  12. HP iPAQ H3850 Screen Replacement: 手順 12、 1の画像 1
    • Locate the four blue plastic clips surrounding the square screen housing.
    • Pry back clips with your hands.
    • Use the plastic opening tool to remove the entire screen assembly from the housing.
    FixBotに聞いてみる
    • Insert new screen into device.
    FixBotに聞いてみる
終わりに
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Carson Horton
メンバー登録日: 04/05/15
131 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team 1-3, Plummer Spring 2015 Eastern Washington University, Team 1-3, Plummer Spring 2015人のメンバー
EWU-PLUMMER-S15S1G3
4 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 38
今までの合計 709
