メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP iPAQ H3850 Buttons Replacement
必要な工具と部品
  1. HP iPAQ H3850 Buttons Replacement, Buttons: 手順 1、 1の画像 1
    • To begin the disassembly of the device, place it on a flat surface with the screen facing down.
    FixBotに聞いてみる
  2. HP iPAQ H3850 Buttons Replacement: 手順 2、 1の画像 1
    • Remove the four screws found on the back cover of the device.
    FixBotに聞いてみる
  3. HP iPAQ H3850 Buttons Replacement: 手順 3、 2の画像 1 HP iPAQ H3850 Buttons Replacement: 手順 3、 2の画像 2
    • Carefully remove the back cover using the plastic opening tool against the grooves along the sides of the iPAQ.
    • At this point, a yellow ribbon will be connecting both the front and back panels of the device. Carefully use the plastic opening tool to detach the ribbon from the connector pins.
    FixBotに聞いてみる
  4. HP iPAQ H3850 Buttons Replacement: 手順 4、 1の画像 1
    • Remove the ribbon cable connected to the display motherboard by pulling the plastic clips on both sides towards the top of the device.
    • Use a plastic opening tool to carefully pull the brown ribbon cable from the connector.
    FixBotに聞いてみる
  5. HP iPAQ H3850 Buttons Replacement: 手順 5、 3の画像 1 HP iPAQ H3850 Buttons Replacement: 手順 5、 3の画像 2 HP iPAQ H3850 Buttons Replacement: 手順 5、 3の画像 3
    • Use the plastic opening tool to carefully remove the display motherboard from its housing.
    • Unplug the connector from the opposite end of the display motherboard.
    • Completely remove the component.
    FixBotに聞いてみる
  6. HP iPAQ H3850 Buttons Replacement: 手順 6、 2の画像 1 HP iPAQ H3850 Buttons Replacement: 手順 6、 2の画像 2
    • Remove three small screws from the corners of the motherboard using a Phillips head screwdriver.
    • Use your hands or plastic opening tool to carefully lift the motherboard out of its housing.
    • Remove two screws from the silver cover using a Phillips #00 screwdriver.
    FixBotに聞いてみる
  7. HP iPAQ H3850 Buttons Replacement: 手順 7、 3の画像 1 HP iPAQ H3850 Buttons Replacement: 手順 7、 3の画像 2 HP iPAQ H3850 Buttons Replacement: 手順 7、 3の画像 3
    • Use a Phillips #00 screwdriver to remove the two screws at the bottom of the device.
    • Use a plastic opening tool to remove the button motherboard.
    FixBotに聞いてみる
終わりに
作成者
5人の作成者と共同で作成されました。
Josias
メンバー登録日: 04/07/15
143 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team 1-3, Plummer Spring 2015 Eastern Washington University, Team 1-3, Plummer Spring 2015人のメンバー
EWU-PLUMMER-S15S1G3
4 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 58
今までの合計 584
