メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
HP dv5-1125nr WLAN Card Replacement
必要な工具と部品
  1. HP dv5-1125nr WLAN Card Replacement, Battery: 手順 1、 1の画像 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr WLAN Card Replacement: 手順 2、 1の画像 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr WLAN Card Replacement, Hard Drive: 手順 3、 2の画像 1 HP dv5-1125nr WLAN Card Replacement, Hard Drive: 手順 3、 2の画像 2
    • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr WLAN Card Replacement: 手順 4、 1の画像 1
    • Remove the plastic hard drive cover.
  5. HP dv5-1125nr WLAN Card Replacement: 手順 5、 2の画像 1 HP dv5-1125nr WLAN Card Replacement: 手順 5、 2の画像 2
    • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
  6. HP dv5-1125nr WLAN Card Replacement: 手順 6、 2の画像 1 HP dv5-1125nr WLAN Card Replacement: 手順 6、 2の画像 2
    • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
  7. HP dv5-1125nr WLAN Card Replacement: 手順 7、 2の画像 1 HP dv5-1125nr WLAN Card Replacement: 手順 7、 2の画像 2
    • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
    • Slide the hard drive out of the enclosure to complete the removal process.
  8. HP dv5-1125nr WLAN Card Replacement, WLAN Card: 手順 8、 1の画像 1
    • Locate the wireless card and the two wires attached to it.
    • Caution: Prying on the WLAN card wires in the wrong direction could damage your wireless card. Make sure to lift straight up when removing the wires.
    • Using a plastic spudger tool, carefully lift up on each wire connecting the card to unsnap the connectors.
  9. HP dv5-1125nr WLAN Card Replacement: 手順 9、 2の画像 1 HP dv5-1125nr WLAN Card Replacement: 手順 9、 2の画像 2
    • Locate the 2.5mm Phillips screw on the corner of the WLAN card and remove it using a Phillips #000 screwdriver.
  10. HP dv5-1125nr WLAN Card Replacement: 手順 10、 2の画像 1 HP dv5-1125nr WLAN Card Replacement: 手順 10、 2の画像 2
    • Upon removing the screw, the WLAN card will pop up. Keeping a natural angle, slide the card out of the slot.
    • The card is now free from your computer.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Cory Mayer
メンバー登録日: 04/01/14
891 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 9-15, Regan Spring 2014 Cal Poly, Team 9-15, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S9G15
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 11
今までの合計 1,152
