はじめに
The dv5-1125nr keyboard is a single piece of plastic and is easy to replace when removed. New keyboards can be bought from HP or online. Unfortunately, it is one of the more difficult pieces to remove.
必要なもの
Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
Begin by unscrewing the three 3mm Phillips head screws inside the battery bay with the Phillips #00 screwdriver.
To reassemble your device, follow these instructions in reverse order. When reinserting the ribbon cable, it should click into place.
2 の人々がこのガイドを完成させました。
