この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Replacing the LCD display is a more costly task, but it is certainly not too difficult.
必要な工具と部品
Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
Begin by unscrewing the three 3mm Phillips head screws inside the battery bay with the Phillips #00 screwdriver.
この手順で使用する道具:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use a 2.5mm flathead screwdriver to remove the four 3mm screws on top of the keyboard.
Locate four 3mm screws in the upper corners of the keyboard tray and remove them using a #00 Phillips screwdriver.
12 の人々がこのガイドを完成させました。
