メインコンテンツにスキップ
はじめに
Removing the battery is usually the first step to reaching the guts of any laptop. HP has utilized a simple one-switch release system to aid in the removal of the battery.
ツール
ツールは指定されていません。
  1. Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. Remove the battery.
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
終わりに
To reassemble your device, follow these instructions in reverse order. Note the release switch does not need to be held down to replace the battery.
4 の人々がこのガイドを完成させました。
Nick Loey
メンバー登録日: 2014年04月01日
1,652 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 9-15, Regan Spring 2014 Cal Poly, Team 9-15, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S9G15
4 メンバー
10のガイドは作成済み
2 件のコメント
Can I return a battery if it does not fit? GLOPAM2013@YAHOO.COM
glopam2013 - 返信
what is your return policy?
glopam2013 - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 1,032
